11-20-2012, 11:12 AM
#61 (permalink)
When coolant gets too hot it degrades and is no longer a useful coolant.
11-20-2012, 11:36 AM
#62 (permalink)
I guess cause my vehicles large, both route through the radiator and the trans has an additional cooler as well
I figured most cars at least have the oil and/or trans oil routed through the radiator, but I guess not
Originally Posted by Daox
Most cars don't even have an oil cooler unless you're counting the trans cooler, and unless your vehicle is large you probably don't even have one of those.
02-22-2013, 12:05 PM
#63 (permalink)
Definately a Modder!
Bump Any new developments here? I need to find a local Toyota dealer mechanic that may have some junk hot coolant storage tanks I can play with
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
02-22-2013, 12:23 PM
#64 (permalink)
EV OR DIESEL
Some thoughts:
1) there is a thread on tdiclub now about using a vaccumme thermos to hold heat (I know not same, but worth a look).
2) how about a big EGR cooler off say a semi? Should be reasonably priced.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
02-22-2013, 06:10 PM
#65 (permalink)
I had up to 1100'F going out my exhaust.
Then I put on a turbo, picked up at least 3 mpg on the highway, 2 mpg driving around town and dropped EGT's by over 400'F.
Gas engines are a little harder to recover exhaust heat from.
07-31-2018, 10:43 AM
#66 (permalink)
off-the-shelf
Zombie thread lives again!
Saw this pic/article and had to post:
BorgWarner Exhaust Heat Recovery System for hybrids can improve fuel economy by up to 8.5%
During engine cold starts, a valve controls the exhaust gas flow, routing it through a heat exchanger, where the thermal energy of the gas heats up the vehicle’s subsystem fluids. As a result, the engine warms up faster.
The Following 2 Users Say Thank You to MetroMPG For This Useful Post:
07-31-2018, 11:10 AM
#67 (permalink)
EV OR DIESEL
Is that the actual Prius unit ?
I keep considering a similar heat recovery setup for an off grid backup generator that would basically only be needed in the dead of winter.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
07-31-2018, 11:12 AM
#68 (permalink)
I think it's a generic unit that BorgWarner developed to sell to other OEMs.
07-31-2018, 12:32 PM
#69 (permalink)
Since this has been revived, why not use a 12V block heater and/or 12V oil pan heater to heat up the fluids? They could be used manually or controlled automatically to come on with the car and turn off at a certain coolant temp (or from the tstat).
How would coolant water (and glycol) degrade? It doesn't break down like motor oil. I'm mean if you overheat it, it would eventually vaporize, but 98'C water is always going to be the same water.
07-31-2018, 05:23 PM
#70 (permalink)
Moderator
Aqueous ethylene glycol decomposes into carbon monoxide and diatomic hydrogen (hydrogen gas) if it gets hot enough.
