Old 02-10-2013, 04:26 AM   #1 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
Mk3 golf Upper grill block for under £3($5)
I've finally turned my hand to some proper ecomodding!
The 1996 golf TD I have has a tendency to drop engine temp to just about 80 degrees when I'm on the motorway at 60mph. This wasnt great- I'd prefer it to be running 85ish, 90 under heavy load (hills etc).. so I decided to sort it!
managed to make a grillblock for the car today- certainly helps with keeping the temp more constant! Sits at 85 all day long, up to 90 for hills-happy!
Also easy to remove if the temp rises
Here's some pics to show how I did it for under £3.00:
£0.79 worth of Pipe lagging and some scissors:
The bare grill (badge was already missing!)
Detail of the slats- where I'm going to slot in the pipe lagging
First piece cut and trial fitted
2nd/3rd/4th/5th pieces fitted
£1.00 can of primer
£1.00 can of Black Paint
The finished article
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 02-10-2013, 10:45 AM   #2 (permalink)
Silver Bullet - '02 VW Golf TDi
Very clever! I wonder if it will impact fuel economy?
Best tank ever: 72.1 mpg in February 2005, Seattle to S.F.
New personnal best 'all-city' tank June '08 ... 61.9 mpg!
Thanks to 'pulse-n-glide' technique.
Old 02-11-2013, 04:56 AM   #3 (permalink)
Team m8
The imact on Fuel consumption will tell whether its clever or not
I just thought was an opportunity to use some spare stuff!
Initial experience (100 miles) suggests that the car is
1. Running more consistently at temps above 80 degrees (A warmer diesel engine is more efficient, within reason) with much less fluctuation.
2. The higher temp, combined with an increase in % of Veg oil in the fuel seems to have had a positive impact on drivability at higher speed.
so far, so good
Old 02-11-2013, 09:40 AM   #4 (permalink)
Improving your fuel economy would be the icing on the cake, but the cleverness comes from solving the overcooling issue with inexpensive materials at hand.
Be sure to let us know if it impacts economy as well.
Old 02-15-2013, 06:39 PM   #5 (permalink)
Burning oil to move air.
ausiasmobil - '06 Seat Leon 1.9 TDI Reference
90 day: 40.22 mpg (US)
EcoTxec - '99 Skoda Octavia 1.9 TDI 110 cv Laurin & Klement
90 day: 52.85 mpg (US)
change your thermostat. Standard one begins to open 87ºC and gets full opened at 102ºC, equilibrium temp on 1.9 Tdi is arund 90.9ºC. (Tested from 0ºC to 45ºC)
Autodata software (maintenance database) says something about 80ºC thermstat in some TDI but I thing it's not true and maybe a mistake, because original parts for engines from 1997 (I/ve seen) to nowadays use 87ºC ones.
Your car is wasting fuel because of your thermostat opens at lower temps and maybe never closes at all.
If you were able to measure the fuel saving with upper grill blocks you will appreciate the big improvement of your thermostat change.
Sold:
Old 02-15-2013, 08:25 PM   #6 (permalink)
Team m8
Thanks for that..
My car is not a TDi though, its TD, the AAZ engine- I'm not sure what the thermostat is for that engine?
Old 02-16-2013, 04:55 AM   #7 (permalink)
Termostato, refrigerante para VOLKSWAGEN Golf III 1.9 TD 75cv a bajo precio (spanish or french)
Yours is a 87ºC, and your thermostat needs replacement because is not closing.
VW dsahboard coolant temp indicatro says 90ºC if real temp from coolant temp sensor says 70 to 102ºC, so if yours says 80 fuel sensor is getting maybe 65ºC.
MAybe you need also a replacement for the coolant temps sensor Sensor temp. refrigerante para VOLKSWAGEN Golf III 1.9 TD 75cv a bajo precio
Ask your repair shop to change thermostat and coolant sensor and put VW G12 coolant (G12+ it is a good option). IT's organic, not water with chemical that reacts when you mix different cheap coolants.
I'm using a 12€ per 5L like this:
IADA · Productos
Technical data:
http://www.iada.es/pdf/producto/ft_glycogel_50.pdf
Safety data:
http://www.iada.es/pdf/producto/fds_...o_amarillo.pdf
It should be liquid from -37ºC to 145ºC.
Sold:
Old 02-16-2013, 08:03 AM   #8 (permalink)
Team m8
IADA · Productos
Technical data:
Safety data:
Excellent- many thanks! I shall investigate the thermostat, and getting it replaced. Certainly does sound like its running cold.
A new thermostat appears to be under £10, so not a massive investment. Coolant is simple enough to get too.
Old 02-20-2013, 08:43 AM   #9 (permalink)
Team m8
First tank is in with the grill block on. Car was running a 20/80% veg/Diesel mix
670.1 miles for 52.58L of fuel
Giving imp MPG of 57.94
thats a 0.37 mpg gain, and I'm happy, bearing in mind the traffic I've had to deal with this week
Old 03-01-2013, 07:24 PM   #10 (permalink)
Team m8
Thermostat now purchased- hopefully get it fitted this weekend, and see how the temp is then.
I'm hoping for a rock steady 90 degrees indicated, with the engine getting there quicker
