Old 12-11-2008, 02:47 PM   #21 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
CRX Si 4 Hole Wheels?
I've been calling junkyards, and all of them seem to want over $200 (shipped) for a set of Insight wheels. Now I'm thinking of buying '80s CRX Si 14" alloys (the ones with 4 big holes). The wheels are flat, and the holes look easy to cover to make a flat disc.
This is the wheel i have in mind:
http://dgbrown.pixesthesia.com/cars/...20CRX%20Si.jpg
Opinions?
Anyone know the weight on these?
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
DeepScale
Old 12-11-2008, 03:15 PM   #22 (permalink)
benefit
Originally Posted by Christ View Post
Hm.. Mooncraft is the counterpart to Mugen, a Honda-option parts mfg... that's funny, although I seriously doubt they're the same company.
As far as real input here, is there any benefit to having domed caps as opposed to flat caps on your wheels? Like helping to re-direct some of the detached airflow from the nose- area of the car and help reattach it to the side?
Obviously, they create a larger frontal area, but I wonder if it's enough to negate any (if any) positive effect they may have?
Moon wheel covers do aggravate frontal area,however provide the highest sectional density,compensating for the tire"bump" eruption,and overall,they offer the lowest drag for a open wheel in free stream,producing the profile of a "Streamlined Wheel"used in aviation,@ Cd0.12 (from Hoerner,Fig.8.13,Page 128.Better even if faired!
Old 12-11-2008, 03:37 PM   #23 (permalink)
Sorry, I botched the link.
DeepScale
Old 12-11-2008, 04:09 PM   #24 (permalink)
CRX wheels
Opinions?
I have these on my '84 CRX.I got them to run the Michelin MXV Green-X LRR tires.I may have a weight for them.It cost me $1,000 for the wheels and tires and absolutely no benefit to mpg.Bummer!-------PS Honda changed their C-to_C bolt pattern in the next gen vehicles.Is that the same fit as your Protege?
Old 12-11-2008, 04:28 PM   #25 (permalink)
aerohead,
Can you explain what you mean by C- and _C bolt patterns? I thought that just about any 4x100 bolt pattern wheel with a high offset would fit on a '90s Protege, Civic, Corolla, etc.
As far as benefits, I'm not out much money if I don't see an FE gain. I found a junkyard that will ship me a set of '86 CRX Si wheels for $150, and I would just transfer my Michelin Harmony tires to the CRX wheels.
I also like the looks of the gen1 CRX Si wheels (sure beats my black steelies)...
DeepScale
Old 12-11-2008, 04:36 PM   #26 (permalink)
C-to-C
aerohead,
I was thinking that they still measure the bolt pattern from center of one hole,across to the opposite hole.That may not be valid anymore.I was interested in a later model HONDA wheel and the parts guys said they wouldn't fit my car,as HONDA had subsequently changed their bolt pattern.-----$150 is a great price if they'll fit! I'll see if I can find that weight.
Old 12-11-2008, 04:51 PM   #27 (permalink)
I'm pretty darn sure the lug sizing measurement scheme hasn't changed.
The only thing besides offset that could prevent a 4x100 wheel from fitting on any 4x100 hub is center bore. Center bore is the hole in the middle of the wheel that allows the hub to sit slightly inside the wheel. It looks like the CRX's center bore is 56.1mm, while the Protege's center bore is 54.1.
Mazda - Vehicle Bolt Pattern Reference
Honda - Vehicle Bolt Pattern Reference
Since the Honda bore is slightly bigger, the Honda wheel should fit over the smaller Mazda hub. However, I would be more hesitant to try squeezing Mazda wheels over Honda hubs.
I haven't found any information about Honda changing bolt patterns in the '90s, though they did go to a 5-lug pattern for the current generation Civic.
DeepScale
Old 12-12-2008, 12:46 PM   #28 (permalink)
IIRC, most stock Honda alloy wheels are relatively heavy. Lighter than steel wheels, but not nearly as light as a lot of the aftermarket alloys.
-soD
Old 12-12-2008, 01:23 PM   #29 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
-soD
I don't think that's true at all, since '85 Si 13" wheels are ~9-10lbs w/o a tire on them, '86 Si 14" wheels are closer to 13lbs w/o a tire, and even most of the mid90's wheels are still lighter than their steel counterparts.
I own both sets.
In fact, I have the 14" Phone Dials (nickname) or "Buttons" on my 4th gen Civic.
PS. Bolt patterns have been measured center to center across the widest point since engineers determined this the most accurate way to measure anything.
As long as the offset is at least 38mm, and the wheel/tire isn't more than a standard width, it will fit on a Honda hub.
In a few seconds, I can get the weights of some pretty common Honda/Acura wheels.
Correction:
OEM steel wheels on 88-91 Civics are 13x5J and weigh 16#
86-87 Alloy wheels are 14x5J, cast wheels, and weigh 15.4#
Honda Civic HX 96-97 wheels are cast alloy, 14x5.5J and weigh 11.8#
Civic VX 13x5J cast alloy, weight 9.7#
Still waiting for weight on '85 Si 13x5J.
Old 12-12-2008, 05:15 PM   #30 (permalink)
My metro needs something domed for mechanical clearence, like most fwd cars I suspect. But the design has been around since what, WWII or earlier? RWD cars don't usually need any center clearence. It certainly is a lot more trouble to 'spin form' manufacture them in a metal spinning lathe, than to just use flat metal. <metal spinning a metal working art that is all but gone>
I agree, there must be some other reason
Honda Insight Wheels Ryland Hybrids 24 04-20-2011 12:45 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
14" Moon Hubcaps, trade for 15"? or sell for cash Sean T. For Sale 2 09-17-2008 04:17 PM
Will smooth hubcaps fit my 2000 Civic wheels? swoody Aerodynamics 15 09-06-2008 12:51 PM
How to install screw on full moon hubcaps crexcrex Aerodynamics 2 08-01-2008 02:38 PM
