Old 09-09-2010, 03:38 PM   #961 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
where did you get your metric code?
Old 09-11-2010, 03:13 AM   #962 (permalink)
this code, I guess
http://opengauge.googlecode.com/svn/...no/mpguino.cpp
Old 09-13-2010, 12:35 PM   #963 (permalink)
dcb
needs more cowbell
dcb's Avatar
how did you compile and load it on your Duemilanove?
Old 09-15-2010, 04:39 PM   #964 (permalink)
arduino 18 or 19 dont remember
Old 09-15-2010, 06:32 PM   #965 (permalink)
dcb
needs more cowbell
dcb's Avatar
I'm not getting a clear picture here.
Old 09-22-2010, 05:05 PM   #966 (permalink)
cmj
Honda - '96 Honda Civic EX
90 day: 36.12 mpg (US)
I'm having trouble with the serial readout, it seems to be spitting out a bunch of unreadable characters.. Code uploaded to Duemilanove via Arduino 0018.
NVM: Figured it out!
Last edited by cmj; 09-22-2010 at 05:26 PM.. Reason: Solved my own problem.. Was uploading CPP instead of PDE
Old 09-22-2010, 05:26 PM   #967 (permalink)
dcb
needs more cowbell
dcb's Avatar
Ok, thx, I think you need a 20mhz crystal plus some other hardware changes if you want to use the latest cpp file without making any code changes.
If starting from an arduino, there is an archived version of the original arduino code here (which probably needs an archived version of arduino ide):
http://opengauge.googlecode.com/svn/...no/mpguino.pde
Old 09-22-2010, 08:27 PM   #968 (permalink)
cmj
My first test was not a successful one. Quick jaunt to the Taco Bell for some dinner, and the MPGuino's data log looks all wonky.
Here's the setup
96 Civic EX - Automatic and Stock
VSS wire - C18 (Blue/White)
INJ1 wire - A04 (Brown)
Breadboard is wired with 22AWG single strand
VSS and INJ wire are 18AWG multi strand
VSS/Pulse Mile - 8208ul
MicroSec/Gallon - 0272500000ul
InjectorDelayuS - 72ul
These settings were taken from a 97 DX Coupe Auto (Wiki)
The following is the data collected. I pulled out a section where I was doing 40mph consistently on flat road.
0.55 1.01 13804 6 3
1.52 4.05 14860 5 5
2.56 7.86 20504 6 9
2.09 7.96 28220 7 10
1.72 8.15 28280 6 7
1.18 7.03 44088 8 10
1.64 10 38044 7 9
1.45 8.9 43656 8 12
1.42 8.63 37788 7 9
1.44 7.42 37864 8 9
1.74 7.85 30876 7 9
1.72 7.8 31076 7 9
1.58 6.89 30332 7 8
1.54 5.94 23524 6 5
1.35 5.1 27232 7 7
Can anyone see any discrepancies?
Power/Ground is soley from my laptop to the arduino. Is this an issue? I figure no since i'm not requiring power for anything other than processing. I just don't know if the lack of chassis ground is my issue.
Old 09-22-2010, 09:00 PM   #969 (permalink)
dcb
needs more cowbell
dcb's Avatar
The guino should be grounded to the chassis for sure.
Old 09-22-2010, 10:58 PM   #970 (permalink)
cmj
Got it! Just took it on a drive to fill up (you know you're a nut when you can't wait to fill your tank) I ended up at 40.5 MPG on this go around. I hinted to my pops that my MPG was ~40% over EPA and his ears perked up. He does a lot of driving and wants to see how far he can stretch a tank now. Since he's got money, I suggested he make a donation to the official opengauge MPGuino project. I told him to hold off until I found out a turnaround time. If he purchases a unit, how soon can he receive it in the Midwest US
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 09:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
