Old 07-02-2008, 12:09 AM   #401 (permalink)
NewBlue - '07 Honda Civic EX
90 day: 38.13 mpg (US)
The Better Half - '97 Ford Ranger XLT
90 day: 25.84 mpg (US)
Can you check the resistance across the buttons? is it just a simple |_| where pushing the button connects two pins? Should be easy to trouble shoot with a meter if you have one?
2007 Honda Civic Ex
Second Goal = 50mpg
First goal = 40mpg Goal Achieved 3 tank average over 40mpg
Starting point 30mpg ready...... GO.
Old 07-02-2008, 12:12 AM   #402 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
There's no resistance across either button, which leads me to assume they're broken.
Old 07-02-2008, 12:13 AM   #403 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
How many leads on the buttons? Where they from?
Old 07-02-2008, 12:16 AM   #404 (permalink)
might have gotten a hair of solder across the pins or just bad buttons, if you really felt ambitious you could de-solder and re-solder one, if that didn't work you could try de-soldering a broken one and the working one and swapping them to see the result, BUT then you run the risk of breaking the third one :-). If your solder job is messy you can pick up solder wick and clean some off, you can also heat up your soldering pen (I hope it's a small tip) clean the tip and draw a line between the solder points this should break any faint connection that might be bridging.
2007 Honda Civic Ex
Second Goal = 50mpg
Old 07-02-2008, 12:21 AM   #405 (permalink)
Dartmouth 2010
SVOboy's Avatar
It seems like I have the wrong poles soldering on the two buttons, will correct it tomorrow.
Old 07-02-2008, 01:02 AM   #406 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Originally Posted by dcb View Post
Having gained a little more experience, I'm starting to like the green displays more myself. They seem more readable even when hot. Need to do a little homework before changing recommendations though (check prices/temperature ranges/availability).
SparkFun Electronics
This looks nice. They also have red on black and yellow on blue. Only 5-6 dollars more.
Old 07-02-2008, 07:27 AM   #407 (permalink)
dcb
needs more cowbell
dcb's Avatar
$6 more seems pretty steep, I think
Mouser has this from newhaven display for $6.98, except it is side pin. But the price is moving in the correct direction And ordering from mouser or digikey (or ???) means you can get some of the other electronic bits needed that sparkfun doesn't stock or that they overcharge for.
NHD-02161Z-FSY-YBW
Needs more digging through product catalogs and spec sheets to keep the price down though.
Old 07-02-2008, 08:06 AM   #408 (permalink)
dcb
needs more cowbell
dcb's Avatar
FYI, got a few questions about power for the iDuino. Here is just the power supply circuit from the PCB thread. The iduino, and possibly other creations, do not have an onboard regulator so you need something like this to make 5 volts out of 12.
Old 07-02-2008, 10:43 PM   #409 (permalink)
Dartmouth 2010
SVOboy's Avatar
^^ Thanks for the above
Anyway, it's working now, all the buttons and everything, just need to do the above and set it up.
How should I find the info I need to set up the parameters? Tank size is easy, but the rest of it? Anyone done this with a cx/vx yet?
Thanks.
Old 07-02-2008, 10:52 PM   #410 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
Thanks.
http://ecomodder.com/forum/31453-post209.html
^ that should have what'cher lookin for.
At least as far as I got before my LCD died.
I'll have to get back at it here next week...
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 09:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
