07-03-2008, 08:16 AM
#411 (permalink)
needs more cowbell
AndrewJ, folks have had some success with just reprogramming it. Also I think asian cars should be 8204 per spec, at least I would start there and calibrate with a road test.
07-04-2008, 01:22 AM
#412 (permalink)
Hi, I am really thinking about starting on this project for my OBDI vehicles. Do I need to snap up one of the v1.0 serial boards before they are gone, or will everything work just the same with a v2.0 serial board? Im running NT4 sp6 so I do not have USB.
Will the board from the Sparkfun Electronics work the same? (Does HD44780 chipset mean it will work the same?) I would much prefer that to be easy on the eyes, as well as match my dash. Also the red/black one would go great with my Pontiac this winter. On my downstate trips I am in the car for 7 hours straight in the dark every other weekend, plus 5 more hours in the dark during the week. I need something easy on the eyes.
I am sure that I have seen the VSS pulses per mile in my factory service manuals, so the injector tweaking should be the main issue. My engines are MPFI V6, bank style firing (3 at a time). I know where all the wires are, Ive done 2 engine swaps.
I have done some programming but with the TI85 calculator and some Autocad lisp but nothing like what I see in this program. Ive built things with similar level of soldering, but Im only familiar with super basic things like relays, resistors. The chip flashing is new to me.
Hopefully I can provide some shared experience to this project and get something working for myself.
Winter daily driver, parked most days right now
Summer daily driver
07-04-2008, 09:19 AM
#413 (permalink)
needs more cowbell
I think 1.0 is gone. I'm leaning towards the iDUINO these days for about the same money plus it has usb. But I need to do some more testing with the oscilloscope before I update the documentation.
Not sure which sparkfun board you mean, got a link?
I'll have some updated recommended hardware shortly. I've learned a few things since that first version.
07-04-2008, 03:47 PM
#414 (permalink)
SparkFun Electronics
This link was from a few posts back.
I would really like a serial version, but if you are going to a strictly USB version, I could most likely use my computer at work to flash the chip. Ill trust you in what you recommend is going to work best.
I did some reading through my 80s and early 90s GM factory service manuals. From what I can gather, it appears there are a few different combinations, but all with the same result. 1- Cable driven speedos have an optical pickup/module as a VSS, which sends 2000 PPM (pulses per mile) to the ECM. 2- Electronic speedos with non-electronic trannys, have a VSS buffer between the VSS and ECM, and it sends 2000 PPM to the ECM, and 4000 PPM to the gauge cluster. 3- Electronic speedos with electronic controlled trannys go direct to the ECM, and the ECM sends 4000 PPM to the gauge cluster.
Summer daily driver
07-04-2008, 11:09 PM
#416 (permalink)
Awesomeness personified
Just downloaded the new code, it fixed my LCD too.
And I know it's about the millionth time anyone has said this, but you're doing an awesome job dcb!
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
07-07-2008, 09:02 AM
#417 (permalink)
Dakota - '00 Dodge Dakota Club Cab, Sport 90 day: 18.57 mpg (US) Jeep - '01 Jeep Wrangler TJ Sport 90 day: 18.46 mpg (US)
Originally Posted by Yoshi
FYI,
Following is VSS information for most vehicles at Rostra Precision Controls site.
Good links, Yoshi, they helped me out, thanks.
07-07-2008, 09:12 AM
#418 (permalink)
SVOboy, I'd appreciate any info you get about switch polarity, whether to get normally open or normally closed switches, how to wire them, etc. I have 4-pin tactiles and I think I'm having a problem similar to the one you are/were having.
Thanks!
07-07-2008, 12:17 PM
#419 (permalink)
The switches I am using are normally-open, 4 pin, tactile switches. The two sides of the switch are each internally connected to 2 pins. I didn't see any markings on my switches to indicate which pins went where, but it was fairly easy to figure out with a continuity tester (or ohm meter). 2 sets of pins will be connected internally without pushing the switch, giving you a "beep" or a 0 ohm reading on your tester. These 2 sets will be either side of your switch. It won't matter which pin of a particular set you choose to wire to. Maybe the following diagram will help. Pins 1 and 2 would be one side of the switch, pins 3 and 4 the other.
07-07-2008, 02:13 PM
#420 (permalink)
Ex-lurker
NT4 SP6? Seriously? You may want to consider one of the Linux options out there....
