Old 11-30-2008, 08:02 AM   #771 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Hi all, just signed up over here because I had some questions, and would like to help with any info if I can too.
The main Wiki page says "see this thread for updates," but the first post in the thread says "no longer updated, see wiki for current info." That may be a little off-putting to new folks.
My Arduino board is on its way, thanks so much for making this project!
Old 12-01-2008, 09:31 AM   #772 (permalink)
Ziggy - '95 Audi S6 Sedan
Manfred - '97 Audi A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 Audi A4 Quattro Avant
Sherman - '98 Audi A6 Quattro Avant
Cab - '96 Audi Cabriolet
Sure enough! The wiki refers to the Release 1 post as the latest info and the Release 1 post refers to the Wiki for the latest. Confusing!
Someone should fix this.
Old 12-04-2008, 01:55 PM   #773 (permalink)
Originally Posted by orange4boy View Post
This cord is all white and there are no colours visible but from the instructions for the wiring on spiffie the male end looks like this. facing the contacts, cord towards you,
this is the female to board config:12V-, 12V+, injector, VSS
this is the cord: VSS, Injector,12V+,12V-
I'ts easy to fix by swapping wires but the instructions should be right.
I'll test the cord later to see if it's crossing over. I did come with my mac for using the fax function although I've never heard of one.
It IS a cross-cable. When it was made, one plug on one end was clip-up, and the other is clip-down.
Moreso seen on phone than on PC network cables. If you were to loot at the ends of your wire, with no twists in the wire, your ends might line up like this:
__---__ (text spacer) _______
|........| (text spacer) |........|
-------- (text spacer) ---__---
Whereas other cables are:
__---__ (text spacer) __---__
-------- (text spacer) --------
Trust me, I've done this enough times making patch cables. If you accidentally flip the wire or the end to be crimped on over in your hands, Pin 1 becomes Pin 4....
Last edited by Nevyn; 12-04-2008 at 02:04 PM.. Reason: argh! ASCII art spacing.....
Old 12-05-2008, 06:08 PM   #774 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
Cross over. That's what I thought. I guess there should be a warning in the instructions that this may be possible
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 12-07-2008, 07:11 AM   #775 (permalink)
EcoModding Lurkaholic
Tercelerat0r's Avatar
White Wallace - '91 Toyota Tercel DX
90 day: 28.44 mpg (US)
Trugly - '92 Isuzu P'Up
90 day: 23.66 mpg (US)
Ugh...I despise and revel in not having a job all at the same time, anyways:
I'm a weiro/geek/person/thingy and use a Mac...how much of a pain would it be to use my Mac for setting a MPGuino up? Yes I do have access to a windows machine, but its a big heavy desktop running 2000 on a Pentium 2 and is slower than dirt, pretty much useless.
Oh the wonders of not following the crowd
Old 12-07-2008, 07:29 AM   #776 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
I would visit http://arduino.cc for platform specifics, though I'm sure someone here has it working on a mac too.
Old 12-07-2008, 11:11 AM   #777 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 39.49 mpg (US)
It should be just as easy as setting it up on a PC. The Arduino program is available for OSX, and the screenshot on the download page looks exactly like the Windows program, so it shouldn't be any different. Just make sure you get Arduino 11 (scroll down on the download page), not the newest version.
Old 12-07-2008, 02:52 PM   #778 (permalink)
The Arduino IDE is Java based, so it's available on all platforms, and is basically identical. What flavor of OSX are you using? I have 10.3.9 and 10.5.2 at my disposal, as well as a USB Arduino...
Old 12-07-2008, 11:11 PM   #779 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
WOOT!
I was right. I reversed the RJ11 wires. Red to 12v+ and black to 12v-, plugged her in and she works!
Should someone inform Fundamental logic? My only question is whether there is such a thing as a crossover RJ11 cord which would be the only other explanation.
Hmm.. my lcd is doing this too; I assembled correctly and my cord seems to be non-crossover though.
Time to try swapping the wires in the RJ box... wish me luck!
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 12-07-2008, 11:46 PM   #780 (permalink)
gascort's Avatar
argh, I wired the 7805 (voltage regulator) in reverse. problem solved. Mine (the 7805 part) didn't match the one pictured in the instructions...
My kingdom for a giant, heated workspace MetroMPG The Lounge 14 12-12-2010 09:08 AM
Motorcycle manufacturers beginning to release MPG info MetroMPG Motorcycles / Scooters 1 04-03-2008 05:23 PM
