Old 11-17-2011, 02:09 PM   #1 (permalink)
multiple air dams??
has anyone ever installed an airdam in front,one in the center,and maybe one in the rear?
Old 11-17-2011, 03:06 PM   #2 (permalink)
How the concept works eludes me, especially the one in the rear.
Old 11-17-2011, 03:09 PM   #3 (permalink)
Lead-footed Econewbie
Ceffy - '97 Nissan Cefiro 25 excimo
90 day: 25.21 mpg (US)
Demio - '07 Mazda Demio Sport
90 day: 30.99 mpg (US)
What are you thinking the centre and rear dams will do? More air deflection? Or do you mean side skirts and rear diffuser?
Old 11-17-2011, 03:33 PM   #4 (permalink)
the concept, is for the second one to block some of the air that does not get blocked by the first airdam.the third might not even work.does this concept still elude you?
Old 11-17-2011, 03:37 PM   #5 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
A belly pan will probably work better to smooth out the airlflow. More air dams seem superfluous.
Old 11-17-2011, 04:04 PM   #6 (permalink)
Yes it does.
I can picture how they could be mounted and how they might look; that isn't the issue. The issue is, airdams (in the front anyway) work not because they are sleek, but because they direct air flow from draggy areas to less draggy areas. So for instance if I were to put one in front of the rear axle on my pickup, what exactly would it do? The "flow" under there is already a complete turbulent mess... it would shield that axle though... directing air up above, like to the floor of the box and all that nasty chassis stuff wouldn't help so a before axle dam would have to go up as far as it can? And/or be angled such that it tries to direct air down to the road? Or out to the sides?
And then there is the idea of one on the back. The very back? Where we are trying to make the wake zone smaller? I guess I can kind of imagine where trapping a rolling wave similar to why it is said that pickups are better with the gate up are better... but.... eh, I don't think the flow situation is the same down there next to the road.
Sven7 (11-18-2011)
Old 11-17-2011, 09:20 PM   #7 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
The only thing I could see is two "mini dams" to direct air away from the rear tires.
Old 11-18-2011, 01:29 AM   #8 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Like Frank said, once the air is under there you will just be adding drag.
Now I have considered trying a sortof wedge shape cross between sideskirts and an air dam in front of my rear axle to force air out .
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 11-18-2011, 02:32 AM   #9 (permalink)
[QUOTE=Frank Lee;270789 So for instance if I were to put one in front of the rear axle on my pickup, what exactly would it do? The "flow" under there is already a complete turbulent mess...
[/QUOTE]I was thinking in front of the axle,before the floor curves.Ok, the rear one was a bad idea.
Old 11-18-2011, 05:12 AM   #10 (permalink)
Sven7's Avatar
Just do Prius style air deflectors in front of the wheels and call it a day!
