Old 07-08-2020, 03:36 PM   #81 (permalink)
GreenTDI's Avatar
GreenTDI - '11 Skoda Fabia Estate R3 1.2 CRTDI
Diesel
90 day: 65.02 mpg (US)
Back from a trip to the beautiful Black Forest in the South of Germany. Like I said before, I didn't expect wonderful consumption figures as I removed the grille block, had +500 lbs of extra weight in the car, and the route went over the fastest highway in the world. I could hold back though as my driven highway speed was mostly around 100 - 110 km/h (or ~66mph) and just the speed limits elsewere.
But there again is the miracle called TDI, and I unexpectedly scored the best mileage for an entire tank. After 1125 km or 699 miles, 39.89 liters or 10.5 gallons went into the tank. That's 66.3 MPG or 3.5L/100km. It seems pretty illogical but I don't mind! The less I pay attention and the more I disadvantage the car, the better the numbers! People would almost think that I'm cheating but no. It simply indicates that there is enormous potential in this funny little engine.
ID:	28663   Click image for larger version
See my thread: https://ecomodder.com/forum/showthre...mpg-38318.html
The Following 2 Users Say Thank You to GreenTDI For This Useful Post:
COcyclist (07-10-2020), jimhs (07-09-2020)
Old 07-13-2020, 02:07 PM   #82 (permalink)
GreenTDI's Avatar
Diesel
A new personal record today! I went under the magical 3L mark, where I didn't get through, until now. Reinstalled the grill block, wheater and traffic conditions were perfect, as I've been also perfecting my driving style. Not using pulse and glide or coasting with engine off, just maintaining steady speeds on flat roads, using momentum going downhill to get back uphill, anticipate all situations and minimize braking and shifting. I must say the average speed remains quite high this way, as I keep the car rolling in gear while other traffic comes to a standstill.
Result: 84 MPG or 2.8L/100km
Distance: 53 miles
Average speed: 47 MPH
Weather: sunny 24°C, 9 MPH wind NW
70% highway at 59 MPH
The car received a thank you in the form of a bonnet pat -> "thank you my friend" He did a fantastic job, even with a weight penalty in the form of a passenger! And that passenger was blown away about that consumption figure, I may have convinced him to hypermiling ...
Old 07-13-2020, 10:35 PM   #83 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
84 mpg US. Impressive!
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
GreenTDI (07-14-2020)
Old 07-13-2020, 11:18 PM   #84 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wow!
Old 07-14-2020, 10:38 AM   #85 (permalink)
Wow!!! Awesome! You did great. I think pulse and glide wouldn't improve much your efficiency as your engine is not oversized.
My trip to France went fine but I couldn't get better than a disappointing 4.2l/100km, with 3 to 4 passengers, luggage and a lot of 110km/h driving.
The Following User Says Thank You to ptitviet For This Useful Post:
GreenTDI (07-15-2020)
Old 07-15-2020, 04:25 AM   #86 (permalink)
GreenTDI's Avatar
Diesel
On the way to 90? Anyway, I remember times - mainly the first years of my car - that a 60 MPG trip was a real milestone. So besides some mods and improved driving habbits, it could be a result of a perfectly broken in engine & tires.
P&G could work in 3th gear at low speeds, or in higher gears after ECU tuning. But I tried it and it's not really my thing. I just love the friendly hum of the engine at constant speeds.
It's not disapointing at all for such a big car at those speeds. I don't think the Octavia will get the same numbers as the Fabia in similar conditions, however, they could come close.
Old 07-17-2020, 09:40 AM   #87 (permalink)
I need to come and check in Holland then...
Old 07-17-2020, 10:34 AM   #88 (permalink)
Luddite
deluxx's Avatar
ol-green - '96 Honda Civic LX
90 day: 50.11 mpg (US)
Wow! Master Driving Skills! Master Operator! Real inspiration! Keep up the good work!
Old 07-18-2020, 11:39 AM   #89 (permalink)
GreenTDI's Avatar
Diesel
Belgium is really far enough! But Holland has potential for even better consumption, as the speed limits are lower, the roads better and the landscape is completely flat.
Thanks, but half the credits should go to my car
Old 07-19-2020, 03:05 PM   #90 (permalink)
You exceeded even the you tube US guy that got 80 some mpg cross country in a heavily modded Golf
