Old 09-08-2009, 10:52 PM   #21 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by McTimson View Post
How much did it cost to put up?
Tower sections $25 (scrap yard FTW!)
Bolts for tower sections $15
Cable $50
Concrete $40
3x 1'x10ft schedule 60 pipe $ unknown(went with steel order)
Time 1 billion hours
$130+
+ WRT54GL $60
+ Parabolic Grid $Already had
+ Ammo Box $ 12
$72
$202 +for my end ? + an unbelievable amount of time + energy
Is there enough wind there to make a windmill out of it?
Wind isn't very good on the tower; i'm only a few feet from the top of a very large oak tree about 30 feet away.
Windmill is in the works; but not very soon, nor on this tower . . . .
I do wish
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 09-09-2009, 02:18 AM   #22 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
Damn you had to go high for WiFi. We only went up 12ft I think
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 09-09-2009, 08:22 AM   #23 (permalink)
EV OR DIESEL
Well; the origional plan was to steal internet from 1/2- 3/4 mile away from existing access points.
If I knew my final setup; I would have done lower; however I am just above 3 trees that I would have to go straight through if I had only done 50 feet. . . . .
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 11-20-2009, 08:53 AM   #24 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
It that because of the over-head?
Originally Posted by dremd View Post
I always forget how huge of a performance hit WEP takes on a marginal link (almost 50%)
Does it take a lot more bits to use WEP vs using Open mode??
I have a buddy across the road who has a very weak signal, resulting in
a lot of slowness. We are using WEP, which I understand is very easy to crack now..
Would my 'user' do better without WEP??
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 11-20-2009, 10:39 AM   #25 (permalink)
EV OR DIESEL
I totally don't know.
If it were me I'd test with security off, test with differant security settings, and if all fails upgrade radios/ antennas.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 11-20-2009, 11:01 AM   #26 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
WEP is essentially useless. It can be cracked offline in 60 seconds using easily-available tools. If you're looking for security, use WPA or WPA2. A powered directional antenna at the AP can make up the speed difference. (I'm sure it's only 10-15% anyway.)
Without WPA, anybody within range of the antenna can capture packets unnoticed and see what's going on, or even use ARP spoofing to do man-in-the-middle attacks.
Old 11-20-2009, 11:29 AM   #27 (permalink)
Using DD-WRT
WEP might not even be needed in this neighborhood. My stock antenna is located in
such a shielded location, it's just about invisible in all directions but one.
My buddy picks it up weakly with his laptop, but it's slow unless he comes outdoors.
A hacker would need to park at the end of my front sidewalk, unless he used a 12' dish.
Maybe I could get away just using a MAC filter??
Cheers,
Rich
Old 11-20-2009, 05:01 PM   #28 (permalink)
Wannabe greenie
90 day: 18 mpg (US)
MAC filtering and SSID hiding are also ineffective against a hacker, although they work against neighboring PCs that "accidentally" grab your signal (Windows is famous for this.)
If you can't get a signal outside of your property line, then turn off WEP and fuhgeddaboutit.
The Following User Says Thank You to Clev For This Useful Post:
Xringer (11-20-2009)
Old 11-20-2009, 08:36 PM   #29 (permalink)
I'll switch to MAC filtering to keep the random laptop from trying to connect to the wrong system.
There is no line-of-sight to anywhere from my router..
It covers the inside of the house just well enough. My Roku box located
back in the den is just able to do HD.. Good nuff..
Cheers,
Rich
Old 11-20-2009, 08:51 PM   #30 (permalink)
EV OR DIESEL
As clarification my setup is running in WDS only mode, with no SSID broadcast, with MAC address filtering on (no reason, but might as well), and with a randomly generated WPA key.
That gives me about a 15-20% performance hit. WEP is what actually puts the BIG hurt on my link.
Bear in mind
remote end (with DSL) wireless is broadcasting at 80 mw through a patch panel (15dbi?) and is receiving from my tower at -80dBm with a -97dBm noise floor for a "quality" (strength above noise floor) of 17dBi
Tower end (my house) is broadcasting at 25 mw through a 24 dBi parabolic grid
and is recieving from the remote site at -75dBm with a noise floor of -95dBm for a "quality" (strength above noise floor) of 20dBi
The resulting link gives me about 8 Mbps from remote site to my tower and about 3 Mbps from my tower to my remote site in good weather. I drop to about 3 Mbps down and 1 Mbps down in severe weather. All of which is irrelevant because I can only get 3 Mbps DSL which is typically 2.5Mbps down and .4 Mbps up.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
Electric Car Wind Generator Charger demo unit bennelson Fossil Fuel Free 12 04-28-2009 11:20 AM
Wind power testing idea extragoode Saving@Home 5 08-21-2008 12:09 PM
Hey y'all ttoyoda Introductions 5 05-28-2008 10:30 AM
A game of Desktop Tower Defense anyone? AndrewJ The Lounge 12 03-22-2008 06:54 PM
