Old 04-24-2008, 09:02 PM   #1 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
My try at a partial grill block
Since from what Ive read, Dodge shadows and plymouth sundances have pretty bad aerodynamics, 0.42 drag coefficient from most sources, I decided to try a partial grill block. Im kinda wary of blocking everything due to engine overheating.
The plastic is plastic wrap from a delicious Digiorno stuffed crust pizza. It seems fairly durable. I taped in on with clear packing tape. I then moved the front license plate up to the other side of the grill, need to get another ziptie for it.
Depending on how hot it runs I may block more of the grill. I also have that bottom opening to work with, though that may someday provide airflow for an intercooler.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 04-24-2008, 09:20 PM   #2 (permalink)
Saving Those Greenbacks
FX2.3's Avatar
Snowy - '02 Ford Ranger XL
90 day: 23.29 mpg (US)
Your paint looks really good for your car's age so I would be worried about vibrations of the license plate eating away at your paint. Maybe the soft side of velcro or something to cushion it.
[/URL]
Old 04-24-2008, 10:09 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
The clear plastic is an easy solution. I did the same with my front plate
I'm having trouble fabricating something for mine (I just have the area similar to the bottom of your Shadow). Turns out, I can't fabricate crap. The plate provided a middle 1/3 grille block.
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 04-24-2008, 10:15 PM   #4 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
clear to me is the way to go! stretch it good and it looks almost like it's not there!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-25-2008, 11:53 AM   #5 (permalink)
2005 CivicEX - '05 Honda Civic EX
90 day: 37.26 mpg (US)
I used plexiglass on mine. It was 10 for the sheet size I needed at Home Depot. It works and looks great. You have a easy shape to cut so it shouldn't be that bad.
Old 04-25-2008, 11:59 AM   #6 (permalink)
Blue - '77 Chevy P/U
i have a 92 3.0 5sp to do ,,i may be able to block the whole grill and pull air from the lower facia ,,looking at a fan up-grade maybe to
Old 04-25-2008, 04:36 PM   #7 (permalink)
bhazard's grille block
bhazard, at Cd0.42, the Shadow's got a lower Cd than what Corvette's had when I was in college.Your slow approach will protect that Mopar powertrain from Btu overload.Good engineering!
Old 04-28-2008, 10:03 AM   #8 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
I just completely covered the grill on my Shadow with duct tape. Then I spray painted it to match.
The whole car is Rustoleum Metallic Blue anyways, so the color matches perfect.
No problems what-so-ever with that. When I stuck some coroplast down the front, I DID have to cut some slots in it to keep the car at the right temperature.
Now if only there is something I could do about the crappy 3-speed automatic transmission.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 04-29-2008, 12:14 PM   #9 (permalink)
bhazard's Avatar
Well, the car was just over 3/4 tank and I topped it off. Tripmeter showed 101mi, multiply by 1.036 to correct it for oversized tires and get 104.636mi. Divide by 2.74 gallons which is where the pump shut off and I got 38.188 mpg. What? Can a partial grill block seriously give you 10 mpg?
Im skeptical, I dont think Im gonna enter this into the fuel log. Ill run it down a bit and do a real fillup first and see.
The leaky transmission was also a quart and a half low on fluid so that makes things even harder to believe.
Best MPG - 36.8
Old 04-29-2008, 09:43 PM   #10 (permalink)
yes, I low fluid=less pickup and power. so more losses at the drivetrain. also have the slipping problem in cold weather.
Grill Block Poll. Ryland Aerodynamics 33 08-03-2017 11:30 AM
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 6 12-21-2014 09:58 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
How to build a partial Grill Block for a Caravan/Town & Country popimp DIY / How-to 21 12-18-2009 03:14 PM
