Old 10-30-2012, 09:17 PM   #51 (permalink)
Honda Ek9 - '96 Honda Civic DX/HX
90 day: 34.17 mpg (US)
Originally Posted by California98Civic View Post
You won't regret it.
Well... I have spent more money on more stupid things than that. Lets see if this ultragauge can get me into this Lean Burn thing that everybody is so excited about!
Old 10-31-2012, 07:56 AM   #52 (permalink)
Civic CX/HX - '97 Honda Civic CX/HX
90 day: 63.77 mpg (US)
Originally Posted by Jakins View Post
Idk lol. Simple stuff like spark plugs cap and rotors fuel filters and keeping the egr and intake manifold clean. My egr gets dirty quick for whatever reason so I clean it like Avery 10-15k miles
I try to keep up on everything but EGR every 10-15k? Do you hawrite up on this? I have only cleaned out the EGR passages on mine.
Excited for good reason too. When in lean burn your MPG normally increase about 10 mpg! It takes a little bit to get used to it, but is worth it!!!!
Old 10-31-2012, 09:58 AM   #53 (permalink)
If that is really true, than money is well worth and I will be excited with all of you.
Old 11-02-2012, 10:43 AM   #54 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
When I said egr, I ment the passages. Just unbolt the cover and clean them out and you can take your ever off, I just spray a shot of carb cleaner Ito the holes on it. Everything with a hole I spray into. Being careful not to put way to much liquid into the combustion chamber. Although carb cleaner evaporates super quick so it should be fine. Just follow the write ups you would find on google.
Also to better describe lean burn (im still new to this, but dont Worry you will Get it too some day) It's like driving down the road and you feel your car bogg down like the fuel injectors just got clogged or something but the only way to tell is with an mpguino if you are in LB or if your injectors are indeed clogged lol.
Old 11-02-2012, 11:36 AM   #55 (permalink)
Here is my plan. Have the ultragauge install, and program it to show TSP, load, impg, I think I might have a wideband gauge in the garage, I might try to see if I can wire it into the stock wideband??? Will update sometime next week once this is all done!
Old 11-02-2012, 08:31 PM   #56 (permalink)
Ultragauge received and installed. Have it program to single page only with load%, TSP, impg, trip mpg... Those are the only one I am I retested in right now. I will play with it more once I figured out lean burn as that's my only focus at the moment!
Old 11-03-2012, 12:08 AM   #57 (permalink)
darcane's Avatar
Have it display the rear O2 sensor. When this goes to 0.000 it should be in lean burn mode.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Outlaws69 (11-03-2012)
Old 11-03-2012, 01:07 AM   #58 (permalink)
Jakins's Avatar
Nice^
Old 11-03-2012, 01:10 AM   #59 (permalink)
I will do that tomorrow morning, thanks!!!
Old 11-03-2012, 01:30 AM   #60 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
The "rear" will be the "downstream" sensor and the UltraGauge will denote it the number 2 sensor.
