09-30-2014, 05:17 PM
#11 (permalink)
Spark plugs. Spark plugs? Spark plugs.
When I bought my old new to me Nissan Almera I first had a test drive and it did well.
When I took it home it was awful. It lurched and held back and was impossible to hold steady.
So I took it back to the dealership and let them investigate.
Turns out they had cleaned the engine block with a high pressure hose, then removed all the electric leads, dried them and put them back where they belonged.
One or two of the spark plugs remained wet and shorted...
I had loose spark plugs on at least two of my bikes. Improper gap width. Lead bridge, charred over, oiled over.
If I suspect a misfiring issue now I pull the spark plugs one by one and check if they look clean and do spark when properly grounded.
Judging the state of the engine by reading the spark plugs solved about half the issues I've had over time.
09-30-2014, 06:13 PM
#12 (permalink)
Welcome! Any pictures of the car?
10-01-2014, 01:21 AM
#13 (permalink)
5 pin sensor
When I changed the plugs on my civic they were twice the gap recommended by Honda, which caused them not to fire correctly. Get the maintenance taken care of and the car will last long after your ready for a new one lol
Don't be too worried about spending big bucks on instrumentation, adjust your tire pressure to max sidewall pressure and you should start seeing a drastic mileage improvement.
Current: 1997 civic lx
Past: 1998hx/1996hx/1997lx/1997hx Cali/1997hx
OG lean burn member
My civic thread
10-01-2014, 09:30 AM
#14 (permalink)
Hypermiler
Good idea about the spark plugs. That's about the easiest thing to change on these Civics. Right up on top, easy access. They're probably old if you don't know the history, and it's a cheap and easy job.
10-01-2014, 09:41 AM
#15 (permalink)
Rat Racer
Replace them with OE plugs. Not what the parts store has on hand that will fit, not what got slapped in sometime over the car's last 15 years, but the actual NGK (or whatever) part number that your car left the factory with.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
10-06-2014, 01:18 AM
#16 (permalink)
Good news! I finally got around to fixing the new rig. So i took the distributor cap off and and the inside of the cap was a disaster... the rotor was corroded pretty bad too. I replaced the cap but since the rotor screw was seized I couldn't get it off without stripping the screw so I just brushed it clear of corrosion. So far no problems!
So I have new plugs/wires air/fuel filter, battery, cap, I ran a fuel system cleaner, checked compression (150 across all cylinders) and cleaned the engine bay. I'm ready to go guys.. thanks for your suggestions and help. I'm going to inflate my tires a bit more next.
The Following User Says Thank You to bro_montana For This Useful Post:
#17 (permalink)
about to post pics
10-06-2014, 01:19 AM
#18 (permalink)
pictures added!
10-06-2014, 02:24 AM
#19 (permalink)
Cyborg ECU
Love this car. Subscribed. Mine and yours are virtually identical as to engine specs. I've posted many (too many?) Details on my mods on my garage page and in my modding thread linked in my signature below.
Welcome and good luck!
James
10-06-2014, 12:09 PM
#20 (permalink)
James
Thanks. I just peeked at your mod thread... wow you weren't kidding. Basically i'm in the hunt for similar spec'd cars so I can get some good ideas for future mods... i'll be checking yours out in depth. PS do you know how much stock lx steel wheels weigh?
