01-15-2012, 02:45 PM
#51 (permalink)
Easter McoModder
Originally Posted by Daox
It is a hybrid, not plugin hybrid. Range is ~1 mile or less in EV mode.
why would it have an "ev mode" if it used this technology?
01-15-2012, 02:47 PM
#52 (permalink)
Easter McoModder
Originally Posted by jakobnev
My car can take a 4x8 sheet inside, but you have to cut it into four strips length wise first.
Question: What do Americans do with all the 4x8 sheets they transport all the time?
roof racks!
01-15-2012, 03:39 PM
#53 (permalink)
A madman
Originally Posted by dieselbeetle
roof racks!
You don't even need those!
01-15-2012, 06:55 PM
#54 (permalink)
Get a trailer if you want to haul 4X8 sheets.
Personally I like the Prius C better.
regards
Mech
01-15-2012, 08:00 PM
#55 (permalink)
Easter McoModder
so...
i find it odd that the eV range isn't mentioned on the Prius V's website.
i find it even weirder that NOONE else knows what the range of the eV mode is either. how frustrating. I'd call toyota, but i don't want to have to dodge them for the rest of my life.
01-15-2012, 10:27 PM
#56 (permalink)
If it has the same 1.4kWh (1.3?) battery pack that the stock Prius has, the EV range will be similar.
01-16-2012, 02:37 AM
#57 (permalink)
Pokémoderator
brucey -
Originally Posted by brucey
So wait, is it minivan size or wagon size?
Easier question:
Does it fit a 4x8 sheet in the back?
I measured it at the LA Car Show. I was measuring for 57". and it *barely* fit, so a 4x8 is no good.
It's close to the same as my mini-wagon, but I would say it has less space in the vertical direction because of the batteries.
I would call it a Toyota Prius-Matrix.
CarloSW2
01-16-2012, 03:24 AM
#58 (permalink)
A madman
regards
Mech
But I already have a 4x8 trailer.
01-16-2012, 04:57 AM
#59 (permalink)
Knut - '07 Toyota Prius 90 day: 50.9 mpg (US) Santa - '00 Hyundai Santamo 90 day: 29.07 mpg (US)
Originally Posted by euromodder
Increasing rpm all over the range, and the biggest contributor to its increased fuel use.
Why lower the end gearing instead of just 1,2 and maybe 3 ?
Sure it's the easier way, but on a hybrid there plenty of more complex things.
dueto the hybrid, the rpm are adapted to the needed level. the gearing has more effect for the elektric parts, than for the rpms.
the V has more drag and rollresistance, so if the prius is geared right, the prius V needs a change for sure.
01-16-2012, 11:03 AM
#60 (permalink)
Hypermiler
The Prius V is also taller than the standard Prius. I think it is about the size of the original Odyssey? The Sienna gets 18-22MPG, so the ~40MPG Prius V looks pretty good for a vehicle that is close in size.
Except... even the old/small odyssey had 7 seats instead of only 5.
