10-22-2010, 02:24 AM
#11 (permalink)
Originally Posted by tumnasgt
I'm surprised they didn't use the airconditioner on reverse for heating, seems like an obvious way to reduce power consumption.
What is going to kill their range in the winter is not the heater but the lack of battery heating, you come out ahead even if you use energy from the batteries to heat the batteries so they are closer to their ideal working temperature, ideally you would have a battery heater that draws power from the charging station but when that is not an option you are going to get more range with batteries warmed using energy from that same pack then trying to drive on a cold set of batteries.
If you just run the heater, lights, radio, wipers and all that other stuff you will cut a few miles off your range but most people will never notice even a 1,000 watt load of an electric heater in a car who's drive motor is pulling 10,000 to 20,000 watts or more at times.
Nissan is one of the few car makers that does not believe in battery thermal management other then a single fan inside the sealed battery box.
10-22-2010, 05:22 AM
#12 (permalink)
chevy volt killer = time + GM
given the choice, Ampera(EU Volt) - Prius - Leaf. I'd go leaf
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
10-22-2010, 08:22 AM
#13 (permalink)
The Leaf's battery is warmed when charging, and apparently it is well enough insulated to keep most of it's capacity for up to 3 days in sub zero temperatures.
BTW, the DOD allowed on the Leaf is 95% = 22.8kWh. They must have a very stable and robust chemistry and construction. This is at least 2.5X more usable capacity than the Volt; while the total capacity difference is 1.5X.
10-22-2010, 08:35 AM
#14 (permalink)
Left Lane Ecodriver
Wow, 95% is deeper than I'd want to go everyday. Is that in reduced performance mode, long after distance-to-empty has hit zero?
10-22-2010, 08:58 AM
#15 (permalink)
Apparently the volt never charges above 80% or discharges below 20%, from what I was told at one of the Electric Auto Association meetings is that this can extend the life of the battery by many years as most of the damaged that shortens the life is done at the top and bottom of the charge in a lithium battery, you don't get as much out of it short term but long term you win.
10-22-2010, 01:45 PM
#17 (permalink)
Originally Posted by Ryland
What is going to kill their range in the winter is not the heater but the lack of battery heating...
Yet another reason to make it an APU-type hybrid. When it's cold, you fire up the APU and use the heat from that to warm the cabin & battery.
10-22-2010, 03:15 PM
#18 (permalink)
0-60 in 7 seconds flat with 2 on board is pretty damn impressive.
10-22-2010, 04:03 PM
#19 (permalink)
Ultimate Fail
( regarding range anxiety )
Whatever happened to the idea of having charging stations installed at Nissan dealerships ?
Almost every town in America has a Nissan dealership nearby.
10-22-2010, 04:11 PM
#20 (permalink)
Pishtaco
It mocks the "sporty" CR-Z's performance specs.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
