Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 12-31-2020, 07:10 PM   #31 (permalink)
Sorry faulty memory, It was called a Slipper Bearing: https://www.bourkeengineprojectllc.com/crankcase/
Rich
Check it out...
The Following User Says Thank You to racprops For This Useful Post:
freebeard (12-31-2020)
Old 12-31-2020, 07:23 PM   #32 (permalink)
I am renewing knowledge of this very interesting engine...
Guys your really need to look into all the information here:
I ran into a guy with photo copies of the scraped together book by Mr. Bourke about the engine... it was a bit of a mess.
It has been cleaned up and is much better form now.
Now if I was struck rich I have a second dream to build, and this engine just might be number one ahead of Gasoline vapor.
Rich
Old 12-31-2020, 09:15 PM   #33 (permalink)
I can see the slipper bearing. Now I have to figure out what the transfer port does.
My favorite interesting engine is the Scuderi split-cycle engine, and it has a transfer port. But it's 4-cycle so probably not much likelihood of combining the two, although the Scotch Yoke might carry over.
I guess the 15° crank offset is a problem.
"We're deeply sorry." -- Pfizer
Old 01-01-2021, 12:17 AM   #34 (permalink)
Scuderi split-cycle still sounds more down-to-earth compared to other breakthrough designs.
freebeard (01-01-2021)
Old 01-01-2021, 12:25 AM   #35 (permalink)
Seems silly, to use a whole piston to do a pre-compression, when a simple super charger, or turbo charger is so much better at cramming in air.
Rich
Old 01-01-2021, 12:30 AM   #36 (permalink)
As in a 2-stroke Diesel?
Old 01-01-2021, 02:57 AM   #37 (permalink)
Seems silly, to use a whole piston to do a pre-compression...
The magic is that the transfer port can be a compressed air tank. So it can run as a compressed air engine. Engine compression is ~150psi, SCUBA tanks hold 1500psi.
Old 01-01-2021, 08:09 PM   #38 (permalink)
Had it been combined with an electric compressor or other auxiliary air supply, could qualify as some sort of hybrid. Makes me wonder to which extent DFCO and engine-braking could be compared to the regenerative braking of a hybrid.
