07-26-2008, 06:38 AM
#11 (permalink)
VIVA LA MPG RESISTANCE
Originally Posted by SuperTrooper
The most comprehensive list I've seen for vehicles that CAN be flat towed is Motorhome Magazine's towing guide:
Dinghy Towing Basics
The Tundra is NOT on the list for 2007 vehicles.
Uh is this for towing a Tundra behind an RV, or towing an RV behind a Tundra?
07-26-2008, 09:34 AM
#12 (permalink)
I wonder if anyone ever uses the towed vehicle to add power for accelerating? Ie, when pulling into traffic or going up a hill, the towed vehicle starts up and adds power, then shuts off the engine.
In theory, this would allow one to use a smaller more efficient engine on the towing vehicle.
07-26-2008, 10:50 AM
#13 (permalink)
Legend in my own mind
That would be an awesome idea for RV'ers, the problem is that the dingy would have to be automatic and probably the size of a full size truck in order to move an rv from 0- whatever. I can't see a yaris making much ground on a full size bus RV ..LOL
Then of course you have 99.9 percent of all automatic tranny's can't be towed behind an RV.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
07-26-2008, 11:39 AM
#14 (permalink)
Good point - the wheels on the towed vehicle would need a freewheel/ratchet installed - it can then push forward, but when turned off, the transmission wouldn't move.
Would be useful even if the towed vehicle was just accelerating its own weight.
07-26-2008, 03:17 PM
#15 (permalink)
I tried EOCing in my 2005 Chevy Cobalt once, and despite it being on that dinghy towable list, I won't be trying it again. I was on a long down-sloping stretch of country road with nobody around, so I popped it into neutral and shut the engine off. I was rolling at about 40mph, brakes and steering felt ok, so I kept going until I got to the stop sign at the bottom of the hill. I kicked the engine back on so I had my power brakes back and came to a stop at the sign.
When I pulled away from the stop the car was acting like a manual trans. with very poor clutch work. Shifts were hard and jerky, and coming to a stop the RPMs would drop to around 500 shaking the whole car before it popped out of gear. It did this the rest of the way home. The car sat for about 30 minutes before I needed it again and the problem was gone, I think it just drained too much fluid from the torque converter, and it never got a chance to refill, or something. I don't know all that much about transmissions. It hasn't been a problem since then (3 months).
07-26-2008, 03:27 PM
#16 (permalink)
Mr. Blue Tape
How long did you EOC adrive? Good to hear nothing bad happened permanently.
My 5 pillars of fuel efficiency:- driving style
- aerodynamics
- tires
- weight reduction
- engine maintenance
07-26-2008, 03:33 PM
#17 (permalink)
It was probably .75-1 mile tops.
07-26-2008, 08:19 PM
#18 (permalink)
Formula - '96 Firebird Formula/Trans-Am 90 day: 19.31 mpg (US)
Your service manager probably wants your money when you burn up the tranny.
The tranny gets it's lubrication pumped from the spinning of the engine. When you put it in N and shut off the engine, the drive shaft is still spinning gears inside the tranny. This is why in manuals they say the car should never be towed above 25-30 mph for short distances in N with out the drive shaft pulled out.
Leaving the engine on and coasting in my '90 Firebird along with other driving style changes shot from an average 12 mpg to 20 mpg. Keep the engine on and keep cash in your pocket.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
07-26-2008, 10:29 PM
#19 (permalink)
Future EV Owner
You guys are freakin' me out about the EOC.
07-26-2008, 11:45 PM
#20 (permalink)
Master Novice
I read a couple of days ago that Ford's next version of - I think it was the Fusion - will be flat-towed capable.
