Old 05-28-2009, 11:46 AM   #1 (permalink)
Eddles's Avatar
Eddles's Astra - '01 Vauxhall Astra ECO4
90 day: 61.03 mpg (US)
Angry Obtaining tire pressure information
Goddamn it, why is it *so* difficult to get tyre pressure informations? I need to choose a tire that can take 51 PSI - for FE reasons, but also because my car manual also specifies a 49 PSI figure for my car. But no-one is willing to give me pressure figures - I just got off the phone from a tyre shop and they refused to quote figures, just palming me off with "40 PSI" and "You shouldn't be going over this anyway" despite me telling them that's exactly what the car manual says. Why is no-one telling me this information - it's just wasting my time and it has taken me several weeks to try and choose a damn tire, and I'm nowhere near my final decision due to the lack of information.
Sorry, I just needed to let off steam.
My aim: to achieve 3L/100km.
Best tank @ 65mph: 864.2 miles 69.36MPGus 3.4l/100km
Old 05-28-2009, 11:51 AM   #2 (permalink)
From my experience... just buy a tire you like. Pump it up to whatever you like and be happy. I run my winter tires on the Matrix (sidewall max of 35 psi) at 50 psi and have run them for two years with zero problems. I've run my 44 psi max sidewall tires on the Paseo for two years at 60 psi with zero problems too. I know people running even higher pressures with no problems. I recommend finding a good low rolling resistance tire, and pumping it up to whatever you want. I doubt you'll have problems. IMO, the sidewall rating doesn't mean a ton.
The Following User Says Thank You to Daox For This Useful Post:
Eddles (09-06-2009)
Old 05-28-2009, 12:02 PM   #3 (permalink)
Eddles's Avatar
Then why do they print the figures there? They wouldn't do that if it was a complete waste of time, wouldn't they? I'm just being curious.
Old 05-28-2009, 12:13 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
On my really cheap low rated tires it seems that I get sidewall rot quicker when I run a lot above the rating, not sure you can really pin it down to any one thing, every tire is different.
Also if I remember some tires don't handle as well at their rated "speed rating" if the pressure is above their sidewall rating, since you probably don't drive 120mph it probably doesn't matter on that regard either.
Otherwise I'm not sure, many of the tires I run above the rating last longer, but some others wear unevenly and end up making my car vibrate.
Again this is from 15yrs of driving I can't really pinpoint if any of the above has to do with higher than normal pressure or not.
Good Luck
The Following User Says Thank You to rmay635703 For This Useful Post:
Eddles (09-06-2009)
Old 05-28-2009, 12:30 PM   #5 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
Goodyear & Michelin (I assume other mfgs. as well)websites list "Max load @ PSI" for their tires. I don't know if it is "max pressure" or not.
Don
Old 05-28-2009, 02:25 PM   #6 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I know from personal experience that the Sumitomo brand can run 51psi max pressures.
Old 05-28-2009, 02:27 PM   #7 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
...... also because my car manual also specifies a 49 PSI figure for my car.
Hi Eddles. That has to be the worlds first car manual that specified such a pressure! Is that because it's the eco model?
ollie
Old 05-28-2009, 02:32 PM   #8 (permalink)
Eddles's Avatar
ollie
Correct. The non ECO4 model with the exact same tire size quotes a figure of between 28-35 PSI.
Old 05-28-2009, 03:22 PM   #9 (permalink)
Tire Geek
CapriRacer's Avatar
Eddles,
Read this first:
Barry's Tire Tech
What you should get out of this is that what is printed on the sidewall is relatively arbitrary - which is why the tire shop wasn't particularly interested in answering your question. They saw it as something outside their need to understand - and in a lot of respects that is true.
But allow me correct a couple of misconceptions:
Yes, they would, if it were a government regulation - which it is!
Don
The way the regulation is worded is that the max load and the max pressure have to be listed. For some reason - and I think it is historic in nature - some folks think these 2 things are related - and most of the time they are not.
The Following 2 Users Say Thank You to CapriRacer For This Useful Post:
Eddles (09-06-2009), SVOboy (08-16-2009)
Old 05-28-2009, 04:27 PM   #10 (permalink)
Eddles's Avatar
Hmm. Interesting information. The guy said massively increasing the pressure above the placard doesn't make much difference - just a couple PSI over should be fine, so I might go for the Firestone F580's which is rated at 44PSI - I'm sure it can handle a few extra PSI.
Thanks very much for your time!
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 09:25 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
