Old 10-18-2010, 11:37 PM   #11 (permalink)
Unfortunately the front is messed up from my dads accident. the front bumper bent way in and the sides of the bumper broke some brackets and bent out. Untill i fix it i dont think pictures would accurately reflect what i want to do. I dont think photoshop would be all that good because its hard to see the curves, it would just look like a picture with the wheel well covered in.
Old 10-18-2010, 11:48 PM   #12 (permalink)
I could make them square boxes so no compound curves. Just flat curves on top and on the front and back. The top of the wheel arches are pretty flat i would just need a good amount of body overlap in front and behind the wheels. Lol.
I would rather keep with the rounded curves of the body and not make it any larger than neccesary but square covers are a last option lol.
Driving home i noticed that trucks have more squared arches than cars. I think that might allow a larger range of tire sizes with the tallest tire sticking up into the top of the lowererd wheel well line but if its shorter tire it will still look okay. But the well has to be wide enough for the biggest tire.
Old 10-18-2010, 11:49 PM   #13 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Too bad, I want to do something for my front wheels but I need to see it before I can make one. How about a front quarter on view in photo shop?
Old 10-19-2010, 12:02 AM   #14 (permalink)
I found an old picture, the angle makes the gap in front and behind the wheel look only 40% of its actual size and the top gap look 80%. A side view would make it look worse. I could take a picture of the rear wheel arch which has chrome plastic trim tomorrow in the light. Only the front bumper is sticking out all funky.
I want to lower the truck if i can afford it and there will be side skirts. The wheel cover will probably go below the wheel skirt level to cover the whole rim.
Old 10-19-2010, 12:16 AM   #15 (permalink)
Wiki Mod
That helps me see what you are trying to fix.
Go for the aero hub caps first. That should gain you glad or more of what the skirts should gain you.
Old 10-19-2010, 01:08 AM   #16 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
miket -
I did a before/after for fun :
CarloSW2
American Solar Energy Society
Old 10-19-2010, 01:45 AM   #17 (permalink)
Cfg can you photoshop the truck with the body lowered, an airdam under he bumper side skirts on the sides plus low wheel skirts front and back?
Heres some pics of 02 tundras.
http://www.atozautolights.com/images...s/TOTU0002.jpg
http://www.digi-go.biz/zje1aaa/dsc_0001.jpg
http://www.tundrasolutions.com/forum...2-new-rims.jpg
Old 10-19-2010, 02:11 AM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
miket -
I'm not really good at 3D images. I like to use the side view of your truck from tirerack.com (the "View [wheel] on Vehicle" option). That way it's not distorted by perspective :
I reduced the wheel gap by 1/2 from the original picture and the bottom of the side skirts match the front air dam.
CarloSW2
Old 10-19-2010, 02:42 AM   #19 (permalink)
What year is that truck? the back doesnt look like mine. Did you lower the truck several inches? why did you stop the wheel skirts so much higher than the side skirts and air dam? high?
Old 10-19-2010, 10:44 AM   #20 (permalink)
That is the "step sided" version of the 2WD Tacoma, I think?
pivoting wheel skirt miket Aerodynamics 40 12-16-2012 11:24 PM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
magnetic articulating wheel skirt miket Aerodynamics 8 10-18-2010 07:33 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
Dream Wheel Skirt. Am I Crazy? 2003protege Aerodynamics 7 05-21-2008 01:40 PM
