Old 11-18-2012, 02:25 PM   #71 (permalink)
Corolla - '88 Toyota Corolla LE
90 day: 32.6 mpg (US)
Thanks aerohead!
I will use this as a good guideline.
Old 12-02-2012, 04:17 AM   #72 (permalink)
Doesn't do, "normal"
Project UpCycle - '01 Honda Rebel Streamliner Build
Team Streamliner
Homers Hybrid - '08 Toyota Highlander Hybrid
moms car - '97 honda accord lx
90 day: 34.93 mpg (US)
Adventure - '98 Mazda Protege
90 day: 33.11 mpg (US)
The Silver Civic - '02 Honda Civic
90 day: 36.15 mpg (US)
I think that it is amazing that 5 feet extra in frontal area means 5 more hp is needed to go 70mph for my motorcycle, while doubling its weight to 466lbs only required half a hp more. I bookmarked the app and will be referencing it several times in my projects to come.
Old 12-30-2012, 02:24 AM   #73 (permalink)
The formula used can be found in this spreadsheet:
Hi MetroMPG,
Thanks for making a great tool.
this link for your excel is no longer working
Would you please post a new link?
Thanks.
Carter
Old 12-30-2012, 08:52 PM   #74 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Hi Carter -
Unfortunately, that spreadsheet was hosted by someone else, offsite. It's apparently gone.
Old 12-31-2012, 04:33 AM   #75 (permalink)
Thanks Metro.
I thought it was you excel.
Thanks for making the online tool. Very helpful
HAPPY NEW YEAR
Carter
Old 12-31-2012, 01:32 PM   #76 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Why didn't I know about this tool until now??
Results for my wife's Toyota Matrix coincide ridiculously close to what my scangauge says.
Old 01-02-2013, 09:12 PM   #77 (permalink)
how to calculate power at a given speed
Hi,
I understand how the forces are calculated as explained in footnote 7, but I'm not understanding how to calculate power.
I think total power = power drag + power rolling resistance + parasitic loads.
I've used the equations from Pamvec chapter 3 of P = 0.5*rho*Cd*A*v^3 + (Crr * Mtotal * g * v) but it gave me some ridiculously large numbers
What is the formula used in the online tool to calculate power?
Thanks.
Carter
Old 01-05-2013, 04:57 PM   #78 (permalink)
power
Originally Posted by CarterX27 View Post
Hi,
Thanks.
Carter
If you have your drag force in pounds,at a given velocity,multiply that by your velocity (MPH) divided by 375 to get your horsepower.
mikeyjd (09-14-2013)
Old 01-13-2013, 11:28 PM   #79 (permalink)
Thanks Aerohead.
After seeing your post, i double checked my calculation and found out that i was using mph instead of m/s.
Old 01-29-2013, 02:22 PM   #80 (permalink)
Tungsten - '04 Dodge Dakota Sport
90 day: 20.52 mpg (US)
Nice calculator
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
