07-24-2013, 12:31 PM
It only gets colder from here...
FYI, for those of us in the Northern hemisphere today, July 24th, is statistically the hottest day of the year. So go on out and set your records now & get your grille blocks, coolant heaters, oil pan heater, etc. ready--from here on out it only gets colder.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
07-24-2013, 02:07 PM
Master Novice
Bring it. We're cracking past the 90s every day and the humidity seems to be stuck at about 99.44%.
I'm from Minnesota. I come alive at 50 degrees. My wife is local and anything lower than 75 she puts on a sweater.
07-24-2013, 02:22 PM
I like cool temps too; MN has been baking for too long now.
07-24-2013, 03:35 PM
Fuel economy aside, I definitely prefer the cooler temps as well. It's just depressing to watch my FE number drop. Every year I try to keep on improving as the temps go down, know that I am improving things and the numbers with come back when spring arives.
Diesel Dave
07-24-2013, 04:25 PM
Rat Racer
No, no, no. The Sun is starting to back off, but things are just getting warmed up: August is Record Tank Month!
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
07-24-2013, 04:36 PM
The sun starts to back off on June 20/21, but today is (supposedly) the peak temperature day.
Diesel Dave
07-24-2013, 05:09 PM
Hypermiler
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
07-24-2013, 09:12 PM
sad but true..
07-24-2013, 10:37 PM
#9 (permalink)
I'd better get out with some testing then. Too bad the apartment complex has nowhere to plug in a block heater in the winter.
07-25-2013, 07:04 AM
#10 (permalink)
thats the BBQ, lawn care, and car wash days around here
