Old 07-01-2009, 04:56 AM   #1 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
P+G doesn't work on my VW
On my last thre commutes I've Been trying out Pulse n' Glide and it doesn't seem to want to work with my Polo - doing it between 65-55mph (go below 55 and you'll p*ss off the British truck drivers!) the car labours on restart as if its running VERY rich, it doesn't matter if I do a key restart or bump ignite. I have given it the benefit of the doubt even though my fuel guage has been dropping scarily fast.... might just stick to Constant/DWL/Drafting
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 07-01-2009, 05:29 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Quick answer: You are driving to fast for P&G to work. It probably would do just fine from 20-30 mph,
Old 07-01-2009, 05:47 AM   #3 (permalink)
Diesel
Ah.... simple answer! thanks - sadly though truck drivers get pee'd if you drive incosistently around about their limiter speed (56mph) - so i don't want to risk going any slower really.
Fringe benefit though - Aero mods 'should' have more of any effect at the higher speeds I commute at!
Old 07-01-2009, 05:49 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yep, I would aeromod and stick with dwl on the highway, it is what I do, at least.
Old 07-01-2009, 12:13 PM   #5 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Hi rob.
Have you tried p&g with the engine on? You could have fuelling issues when it starts maybe? Could it also be the case that you were too heavy on the throttle during the pulse? I'm just throwing ideas out there so feel free to put me straight! I'm guessing you don't have a scangauge so you have no readout of the engine LOD to pulse properly. Although seat of the pants works well for me.....
Best of luck.
ollie
Old 07-01-2009, 12:27 PM   #6 (permalink)
Diesel
nope no scan guage, I plateau'd back the throttle before cutting the spark, my friend say it might be the simple electronics the dub has in that it knows its moving from the speedo but isn't sensing combusted gas at the lambda so chucks more and more fuel in - then when you restart it runs rich til it settles out again.
Old 07-01-2009, 09:28 PM   #7 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.23 mpg (US)
If you're just cutting spark you won't see much/any savings. You guess correctly, when the engine loses power the computer tries to compensate, and ends up dumping more fuel into the engine.
Old 07-01-2009, 10:37 PM   #8 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Trucks over there have a 56mph limiter! Jeez... I get passed by 'em if I'm only doing 70mph in the slow lane over here.
Old 07-02-2009, 12:57 AM   #9 (permalink)
Diesel
Yep and they're on allowed to use two of the three lanes too!
Old 07-02-2009, 02:07 AM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I believe that truck speed is limited to 80 km/h in the whole EU. But... even though Polish laws prohibits trucks from going over 80 km/h, and states that they must have a speed governor, I often can't catch up to trucks when I'm going 100 km/h.
Phil Knox's aero-modded 1970 VW van aerohead Aerodynamics 23 01-13-2013 06:28 AM
ScanGauge Questions for a VW Diesel. Deezler Instrumentation 13 07-09-2010 07:42 PM
VW Lupo crash tested by the NHTSA tjts1 General Efficiency Discussion 19 07-02-2009 07:18 AM
Will this work for my metro thefirebuilds General Efficiency Discussion 4 12-27-2008 11:45 AM
New USA Energy Policy NeilBlanchard General Efficiency Discussion 18 11-17-2008 12:54 PM
