Old 03-28-2018, 03:44 PM   #41 (permalink)
Pix pleez.
Once it's all secured with tape, four coats of Plastidip. I'm sure there's a combination like Pearlizer over Real Aluminum that would closely match your paint.
Cutting concave curves on the sides and convex across the top is the modern style.
"We're deeply sorry." -- Pfizer
Old 04-01-2018, 02:33 PM   #42 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
So I’ve noticed my Kamm lifting as I drive... as speed increases, the trailing edge rises... I still think I have more drag than without the visor/Kamm... in the rain the water seems to be moving almost horizontally across the backlight...
My current Ecotec project...
My last Ecotec project...
Old 04-02-2018, 04:16 AM   #43 (permalink)
Team Saturn
So I took off my Kamm for revision and am driving the car without it while it’s being reworked(slot in front and better edge reinforcement)... as it was, it seems to have been costing me a few percent... instant MPG with the visor/Kamm on was around 31@43-45% load (remember this thing is running on three cylinders and in open loop) and with the Kamm off I can hold 55mph at around 38-40% load and about 36mpg instant...
I thought of cutting a whole new one a little longer(16”vs 14”) and positioning it a little lower on the glass(1.5” below the top of glass instead of st the top)... such a visor and position would yield the max length possible without interfering with the trunk lid...
The Following User Says Thank You to 19bonestock88 For This Useful Post:
Ecky (04-02-2018)
Old 04-02-2018, 06:22 AM   #44 (permalink)
90 day: 40.51 mpg (US)
Fully warmed up, and with similar weather?
Aerodynamics is a bit of a black art.
Old 04-02-2018, 06:43 AM   #45 (permalink)
Team Saturn
Car was at normal operating temp, and it was a little warmer/dryer when I was driving with the visor on the car(should have made its mileage better in comparison to my recent trip with the visor off)... temp difference wasn’t huge and the road moisture difference wasn’t too bad either...
Old 04-02-2018, 09:44 AM   #46 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
"Kammbacked" Civic sedan
Tardy reply - apologies...
Originally Posted by mpg_numbers_guy View Post
I know there have been myriads of threads related to kammbacks and boattails for hatchbacks, but how about sedans?
I "Kammbacked" my 2007 Civic so that I could later add a full tail and keep the "template" curve.
Unfortunately, the Kammback mod on its own (no tail) appeared to make NO difference in A-B testing:
I actually also compared Kamm alone (no tail) vs. bare car, and the Kammback appears to have made no difference. 49.2 mpg with it on, 49.2 mpg with it off, 8 runs total (each way).
Build thread: http://ecomodder.com/forum/showthrea...dan-31498.html
The Following 4 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (04-07-2018), BamZipPow (04-02-2018), Ecky (04-02-2018), freebeard (04-02-2018)
Old 04-02-2018, 11:07 AM   #47 (permalink)
@MetroMPG, what were your construction materials for that kamm?
Old 04-02-2018, 12:10 PM   #48 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
One snowstorm a few years back, this is the shape the wind came up with on a parked Civic:
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 04-02-2018, 12:17 PM   #49 (permalink)
Some snow kamms I've seen locally:
Old 04-05-2018, 09:15 AM   #50 (permalink)
The old Snow Kamm Thread - I like that term Ecky.
http://ecomodder.com/forum/showthrea...ing-27509.html
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
boattail, civic, kammback, sedan
