Old 05-25-2018, 09:02 AM   #3261 (permalink)
Yes you can improve it by more voltage, to physical limits. On my dc series brush arc increases until the arc goes all around the commutator until it hits the opposite pole then it becomes a zorch.
On an induction motor eventually you either overheat or experience dielectric breakdown.
Also: most power motors have physical rpm limits. Series dc has the lowest for size due to all that wire mass in the armature
MPaulHolmes (05-25-2018)
Old 05-26-2018, 07:42 AM   #3262 (permalink)
PaulH
MPaulHolmes's Avatar
My understanding is, for motors with buried permanent magnets (high saliency they call it for some reason), you get some torque from the steel in the rotor, near the edges of the magnets, almost like an induction motor, and you get some torque from the buried magnets. To get the torque from both, you have to do a maximum torque per amp correction so that Id is negative (by some amount dictated by some hideously ugly formula based on several things including the "lambda" of the magnets, whatever that is). The correction isn't very hard to implement in the software though. Once you have the Id, then you can find how much of the rest of the current goes to Iq, based on the throttle command (you use the pythagorean theorem at that point to solve for Iq, since throttleCommand^2 = IdCommand^2 + IqCommand^2).
For a nonsalient motor (magnets on the surface) you have your throttle command, and you have to divvy it up between Id and Iq. Usually Id = 0, and Iq = throttleCommand. If you run out of voltage, and you don't like how fast the motor is spinning, you want to fight against the permanent magnets, you make Id negative, but then you waste some of the torque of the motor. But it's a tradeoff when you want the motor to spin faster (at the cost of lower torque).
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
freebeard (05-26-2018), thingstodo (05-26-2018)
Old 05-27-2018, 08:09 PM   #3263 (permalink)
This idea for a hub motor was apparently good because could be adapted to any rear drum brake (plug & play) , but , again the permanent magnets and reluctance have ruined the development:
"hub motors with permanent magnets are not the best technical solution " :
Green Energy Management (GEM) Updates | Middle Tennessee State University
Old 05-28-2018, 12:01 PM   #3264 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
I have read about many hub motors in the past. The hub motors on bicycles and motorcycles seem to be solid. They have bearings on both sides of the hub and this appears to make a difference to reliability. That said, there are not many bicycles or motorcycles with 100,000 miles on them.
So far, all the hub motors that I have read about or seen videos on ... that are supported on one side only ... when you can get details about reliability at all ... seem to experience catastrophic failure before the first set of tires is worn out. Most of the prototypes just seem to disappear and no one wants to talk about them .. or even admit that there was a prototype at all?
The clearances on the motor do not appear to allow for much bearing wear. The wider the motor, the further the rotor is from the bearing. Plus, of course, there is no suspension on the wheel. When the rotating part meets the stationary part ... bad things happen
I'd love to be proven wrong on this one - it's such a practical idea to move the motors out of the vehicle and contain them within the wheels, get rid of the transmission, the extra weight ... there are just so many positives!
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 06-13-2018, 06:18 AM   #3265 (permalink)
Originally Posted by MPaulHolmes View Post
The PI ratio was just a variable that was there for when the "auto" PI test was running. It gave a starting point for how to check a bunch of values. So, if you had the PI ratio be 100, the "run-pi-test" would do:
Kp = 100
Ki =1
Kp = 200
Ki = 2
but it doesn't come into play when you are independently setting Kp and Ki. So, let's say you did this:
pi-ratio 50
kp 1000
ki 10
the variable named "pi-ratio" would still be 50, even though now Kp / Ki = 100.
The rotor time constant can vary a lot from one motor to another. The motor will run horribly if you are way off. It will run OK if you are a little off, and it will run the best if it's perfect. The "run-rotor-test" only works on an unloaded motor. I"ve only ever tested it on a bench with no transmission. If a transmission is hooked up, you man need to change the default commanded Id and Iq in the rotor test function "RunRotorTest" from
IdRefRef = 300
IqRefRef = 300
To something bigger. Those numbers just worked OK for me on a bench with a unloaded motor at maybe 60v or whatever it was I was using for the test.
If you can't get the run-rotor-test to work, you can just try guesses from 5 up to 150 (5mS up to 150mS for the rotor time constant):
rotor-time-constant 5
rotor-time-constant 6
rotor-time-constant 150
and see what gives the best acceleration.
Arber, does your ABZ encoder have a single index pulse per mechanical revolution, or is it 4 per mechanical revolution? That's the only difference from motor type 2 to motor type 3. One possibility is your encoder doesn't like one of the settings below:
I would try changing "DFLTCONbits.IMV = 0b00;" to
"DFLTCONbits.IMV = 0b01;", or DFLTCONbits.IMV = 0b10;, or DFLTCONbits.IMV = 0b11;
Those are the possible required states of A and B, when the index pulse happens, and I don't know what state A and B are in when the index pulse happens on your encoder, so you would just have to try them all. This is why companies pick a specific motor and specific position sensor and just make a specific controller for it. Everybody has their own standards.
Sorry i totaly missed your post there....
You just explained everything to me! My encoder has chip generated signal obtained from rotated magnet. That means signal is basicaly generic encoder AB phase shift with single pulse per circle. All signals are square weaves and at least 90deg of square is overlapped by next signal. Z signal is 1/4 of AB signal period, so is quite short pulse at the rising edge of A and falling edge of B.
This was the reason that Leaf motor wasnt willing even to start turning in mode 3. It just shook there and i could hear amps straining until inverter block was overheating.
In mode 2 it was turning good, but if i used U higher than 200V everything started downhill....
A
Old 06-21-2018, 05:57 PM   #3266 (permalink)
Sorry for the delay, you know how life can be
I was able to get some probes on my three current sensor (L31S200S05FS) outputs and take some basic captures while attempting to throttle up.
These are taken right at the J8, J11, and J14 terminals, which explains the dirty signal. I also quickly checked the spectral contents of one of these signals, and it looks like the (relatively) high frequency is primarily at ~10kHz. I'm not sure where this is coming from, as the ATTiny should be either 62.5kHz or 100kHz; I'll have to do another FFT, this time up to around 200kHz. I'll also verify (again) the output of the ATTiny to make sure it's not acting funky.
I'll follow up with some pics of my setup as well in case there's anything obvious that I'm missing. Here's a link to a short clip I took of myself attempting tho throttle up a few times: https://streamable.com/a6heg
I've got too much invested in this not to see it though to the end
ID:	24437   Click image for larger version
ID:	24438   Click image for larger version
ID:	24439   Click image for larger version
ID:	24440   Click image for larger version
ID:	24442   Click image for larger version
ID:	24443   Click image for larger version
ID:	24444   Click image for larger version
ID:	24445   Click image for larger version
ID:	24447   Click image for larger version
ID:	24448   Click image for larger version
ID:	24449   Click image for larger version
ID:	24450   Click image for larger version
Old 06-21-2018, 10:40 PM   #3267 (permalink)
Here are some pics of my setup. I'm not sure if the method I'm using for the motor phase connections is okay. From what I can tell, the EM57 has the inverter mounted directly above the motor with bars going down into it. This doesn't use cables, so I ordered and cut some copper bars myself.
Once things are more functional, I'll put together an enclosure and mount things which should let me shorten a lot of those wires. Maybe I'll consolidate them into a connector(s).
Paul's encoder-resolver board seems to be wired up and working properly. I believe I've verified this, due to seeing one mechanical revolution cause poscnt to go up to 512 four times
ID:	24470   Click image for larger version
ID:	24471   Click image for larger version
ID:	24472   Click image for larger version
ID:	24473   Click image for larger version
ID:	24475   Click image for larger version
ID:	24476   Click image for larger version
Old 06-22-2018, 02:00 PM   #3268 (permalink)
PaulH
Have you checked that the 6 isolated supplies are all getting about 23.5v or whatever? Also, have you loaded the .hex file with the #define DEBUG uncommented? That's a good way to verify that the PWM signals from all 6 drivers are making it through to the other side. Make sure the current sensors are also facing the arrow pointing away from the IGBTs. I'll check your picture in a sec to check that if I can.
kits and boards
Old 07-05-2018, 10:11 PM   #3269 (permalink)
Ale Madeo
ale0502's Avatar
pwm frecuency
Hi,
I understand that the pwm frecuency must be 10KHz, but on my board is about 3KHz.
My crystal is 8MHz.
What could be wrong?
Thanks
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
Old 07-07-2018, 11:49 AM   #3270 (permalink)
Originally Posted by ale0502 View Post
Hi,
My crystal is 8MHz.
Thanks
The AC Controller had an upgrade a while ago that changed the PWM frequency from constant to a sort of 'white noise' signal that makes a 'SHHHH' sound. I think the frequency varies from 2 KHz to 10 KHz to do that. But I don't know what triggers the change in PWM frequency.
Why do you think that 3 Khz is wrong? Is it not working? The PWM frequency has some effect on efficiency and motor speed control ... but as far as moving your car it should make no difference at all.
Is the noise bothering you? Does it stay at 3 KHz while you drive?
And, is it connected to a motor and driving your car, or are you still testing and it is on your work bench?
The Following User Says Thank You to thingstodo For This Useful Post:
ale0502 (07-07-2018)
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
