Old 01-23-2019, 09:50 AM   #3351 (permalink)
There was a comment over on diyelectric that the throttle pot needs calibrated parameters to initiate the gates and subsequently turn on the igbts. May need other things calibrated also.
esali1987 (01-26-2019)
Old 01-26-2019, 02:51 PM   #3352 (permalink)
Ah ok. Ill look into that. I am only using a small pot for now. This pot is outputting 0 and 1023 just fine. would that need any calibration?
Old 01-26-2019, 05:18 PM   #3353 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Exclamation
As long as you have the pot in the range of 'no movement' when you power up the controller you should be fine.
The settings (on my controller) are:
Code:
fault-throttle-position=0005
If the throttle input goes lower than 5, ignore the throttle. It's a fault - short circuit.
Code:
max-regen-position=0025
At this value, you are commanding maximum regenerative braking
Code:
min-regen-position=0400
At this value, you are just engaging regenerative braking. It scales linearly from min to max position
Code:
min-throttle-position=0624
At this value, you are just engaging the throttle forward. It scales linearly from min to max position
Code:
max-throttle-position=0972
At this value, you are putting out maximum throttle.
So between 400 and 624, using these settings, is where the throttle should be when you power it up. Raise it to go forward, lower it to 'brake'
I don't remember a fault that is thrown if you are over max throttle. Not sure what happens.
Remember that the throttle is commanding TORQUE, not SPEED. So max throttle is trying to push your max CURRENT through the motor to develop that TORQUE. Keeping the throttle in the same position with a motor on your bench will accelerate the motor up to your maximum speed - at least that's what it did to me.
But only if you have enough voltage on your pack to hit your overspeed setpoint.
NOTE - you don't need to have your throttle near MAX in order to put an unloaded motor up to your max speed. As long as the commanded current will get you to max speed, it will go there. If your throttle is low, it will take a while to accelerate to max speed and trip.
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Last edited by thingstodo; 01-26-2019 at 05:20 PM.. Reason: Forgot to add note about throttle not being at max
The Following User Says Thank You to thingstodo For This Useful Post:
Old 01-26-2019, 08:46 PM   #3354 (permalink)
Does the precharge circuit and HV pack have to been hooked up for this to happen?
Thanks
Old 01-27-2019, 11:33 AM   #3355 (permalink)
Thanks
On my control board, the precharge and main contactors were timed. They clicked when they should have, but only if the throttle was there and was in the dead zone between forward and regen.
If there is no HV pack, the motor won't move. The 12V battery used for the controller ONLY provides power to the control board.
I didn't check if the IGBT drivers fire with no HV pack. I assume that they would, since the control board doesn't really know if the HV pack is there .. at least it didn't in my version.
esali1987 (01-30-2019)
Old 01-27-2019, 03:40 PM   #3356 (permalink)
Im slowly putting the invertor together, has anyone got the pin out for Pauls resolver to encoder board, I currently have ver 1.2, Paul sent me a diagram of ver 1.3 but the pin out looks different , I dont want to chance it.
Old 01-31-2019, 06:30 AM   #3357 (permalink)
jackbauer's Avatar
The following takes place between 11am and 12pm. Events occur in real time.
Name:	2019-01-31 11.18.26.jpg
ID:	25496   Click image for larger version
Name:	2019-01-31 11.19.32.jpg
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 01-31-2019, 07:50 AM   #3358 (permalink)
jackbauer's Avatar
12pm to 1pm
Name:	2019-01-31 12.06.37.jpg
ID:	25498   Click image for larger version
Name:	2019-01-31 12.47.59.jpg
www.evbmw.com
Old 01-31-2019, 11:06 AM   #3359 (permalink)
jackbauer's Avatar
3pm to 4pm (Yes I took a break)
Name:	2019-01-31 14.24.35.jpg
ID:	25500   Click image for larger version
Name:	2019-01-31 14.43.45.jpg
www.evbmw.com
Old 02-04-2019, 10:01 AM   #3360 (permalink)
jackbauer's Avatar
Question time : Do I need to use 3 current sensors? or will two suffice. From what I can see the fault logic at least requires 3 current sensors.
www.evbmw.com
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
