Old 03-09-2019, 01:14 AM   #3401 (permalink)
PaulH
MPaulHolmes's Avatar
I don't really understand what T, S, and R are. Do you have any waveforms?
kits and boards
Old 03-10-2019, 12:52 PM   #3402 (permalink)
Ale Madeo
ale0502's Avatar
Question Voltage measurment
Hi everyone, I have a quick question, does the controller need to measure the voltage of the battery bank or any other point of the setup?
thanks
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
Old 03-10-2019, 03:09 PM   #3403 (permalink)
PaulH
It doesn't use the battery voltage for anything at this time.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
ale0502 (03-10-2019)
Old 03-10-2019, 05:46 PM   #3404 (permalink)
Ok Yeah ill need to get an ocsilliscope for that part for sure and I saw, Paul, that you have a resolver to encoder board. SWEET!!
Another thing came up that I am curious about. I can only seem to get the board to put out a signal if the pickit3 is hooked up and not with the USB terminal. Is the onboard USB just for programming as a "Program Mode" and need to be disconnected for "Run Mode"? I have got my motor to move when the PICKIT3 is hooked up only.
Thanks
Old 03-10-2019, 08:58 PM   #3405 (permalink)
Ale Madeo
ale0502's Avatar
Question
Thanks Paul!
I think I'm missing something to connect, because when I run the run-pi-test routine nothing happens, the engine does not turn at all.
I have the two current sensors (LEM HASS 300), and an encoder of 512 steps working by the tests I could do.
What can I have wrong? I have a code written by me with which I throw a frequency without any kind of control and the motor turns, so I have all the power stage running.
thanks
Old 03-13-2019, 12:14 AM   #3406 (permalink)
controller assembled.
Hope to start testing on an HPEVS motor tomorrow.
https://photos.app.goo.gl/Ub14H7pDYxSPZ9r16
Old 03-13-2019, 09:33 PM   #3407 (permalink)
It looks like I'm in the same position as the previous two posters. I believe everything is hooked up correctly. Using the "stream" command I have verified the throttle, temperature sensor and encoder are working as expected. When I "run-pi-test2" it does not drop to zero but stays very close to 512. Nothing I have tried so for has made the motor turn. No error messages on startup except the one that says its not really an error. Does anyone have any suggestions as to what I might have missed??
(I'm testing with a 50 volt battery pack)
Old 03-14-2019, 11:10 AM   #3408 (permalink)
Some mention you need to calibrate the throttle before it runs.
Old 03-14-2019, 07:54 PM   #3409 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Check out @jackbauer's post here
https://ecomodder.com/forum/showthre...tml#post590417
If the vector output is not being called, there should be no output.
Besides that, a while ago you needed to have your throttle between min-regen and min-throttle (I didn't look up the actual variable names - sorry). Not sure if that is a requirement any more.
I can look tonight and find a config that worked OK for my motor. It won't likely work well for yours, but it should output *SOMETHING*
My bet is on the vector output still commented out. Do you have MPLab X installed so you can compile? If not, perhaps send @MPaulholmes or @Jackbauer a PM. They can send you a new file to load into your controller.
I've never gotten this darned compiler to spit out an actual file without errors .. so I can't help with that.
PS - I'm running a rev 2 board and I think you are all at rev 3 or 4
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
59Morris (03-14-2019)
Old 03-14-2019, 09:24 PM   #3410 (permalink)
We have it working...
Thanks thingstodo. I have been in contact with Paul and he sent me a new .hex file that fixed the problem.... after I also fixed a wiring problem of my own. I had crossed up the V and W phase current sensors. Tomorrow I can work on fine tuning the config.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
