Old 12-08-2009, 07:59 PM   #2711 (permalink)
PaulH
MPaulHolmes's Avatar
It has to be compiled to 8kHz.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
watt-a-mezz (12-09-2009)
Old 12-09-2009, 09:19 AM   #2712 (permalink)
jackbauer's Avatar
Ok i've gotten some very strange things happening with v1.5. I built up the budget control board and loaded v1.5 8khz. Connected up the pc with latest rtd running. Data rapidly scrolls down the black text box on the right but the graphs and the raw data readout on the top right do nothing. Any ideas? I'm going to drop it back to v0.9 which i know works to see what happens.
Old 12-09-2009, 09:39 AM   #2713 (permalink)
EVVette - '71 Chevy Corvette Coupe
Hey Jack,
Thats RTD Explorer. I got a new version I will upload in a few moments. 1.5 includes battery amps and Amp Hours used. The new version of RTD encorperates these changes.
I have also fixed the bootloader so that it works ever time!!
The display in the bottom right shows Amp Hours used which is caculated by the controller ever 1 ms.
I will upload the new version to the server by 10AM EST. Then you you can use the update feature in RTD to update to the latest version.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 12-09-2009, 10:07 AM   #2714 (permalink)
jackbauer's Avatar
Great stuff adam many thanks. Here's a mad question for you! Could rtd run on the iphone?
Old 12-09-2009, 10:35 AM   #2715 (permalink)
Hey,
I would love to create an Iphone version, But it would basically be writing the program from scratch. I also dont know how to program for the iphone, and you need to be accepted to use the 30 pin connector.
Here is the link for the update for the program.
www.adambrunette.com/publish.zip
-Adam
Old 12-09-2009, 12:01 PM   #2716 (permalink)
jackbauer's Avatar
adam i downloaded the new version (0.2.0.21) and its the very same. The data scrolls in the black text box but the graph or raw data does nothing.
Old 12-09-2009, 12:06 PM   #2717 (permalink)
Hey Jack, I remember why now. basically the string of rtd data is different then what the program needs. The program is writing all the data to the box there because it thinks its bad data.
The best bet right now is to use 0.9 like you said. I should havve the updated version out some time tonight. I have to wait till I get home from work to work on it.
Sorry.
-Adam
Old 12-09-2009, 12:27 PM   #2718 (permalink)
Out of my mind, back in 5
It would probably be easier to just hook a bluetooth device to the controllers serial port and make the iPhone read that... Would be sweet...
But I'd say that's a couple of revisions in the future...
Old 12-09-2009, 12:29 PM   #2719 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
you will have to hack if you want iphone bluetooth, they hid it from the devkit
but when there is an open source iphone then lets talk, eh?
Old 12-09-2009, 12:32 PM   #2720 (permalink)
Well... Since mine is already jailbroken, that's not really a big problem...
Mine already talks to a few of my projectboards and can control them...
But it would probably be easier to just use a small computer onboard the car... say a 7" touchscreen and a submini itx board and you could do a lot more...
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
