Old 12-22-2009, 03:57 AM   #2781 (permalink)
jackbauer's Avatar
Have to agree that usb is rubbish. Was at an arizona microchip training course a few years ago when they were first bringing out pics with onboard usb. Took the guys a day to get it to send simple ascii characters. Best bet is to get a pci rs232 card if you have a desktop or pcmcia card for a laptop. I have both and work fine with my own projects and rtd explorer. Trouble with most usb to rs232 adaptors is that they are implemented in software.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 12-22-2009, 04:08 PM   #2782 (permalink)
Originally Posted by jackbauer View Post
Best bet is to get a pcmcia card for a laptop.
Why didn't I think of that! Good idea.
Actually I just did a google search and found that the pcmcia card cost half as much as a new laptop!
Old 12-22-2009, 04:17 PM   #2783 (permalink)
check to see if you actually have pcmcia or cardbus.
i've found the usb less fragile. and much cheaper too.
monoprice has some good deals. a top recomend for cables,...
http://www.monoprice.com/products/se...ord=232 to usb
Old 12-22-2009, 04:24 PM   #2784 (permalink)
As far as I can determine it is difficult to use synchronous protocols on a USB-232 converter, due I suspect to what Jack mentioned, software implementation. Also I believe that windows has its own way of using interrupts that is unpredictable.
Old 12-22-2009, 04:26 PM   #2785 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
RS-232 to USB
monoprice has some good deals. a top recommend for cables,...
Well, there is not only the price and robustness, is communication speed and collition rate of data being handled by the com port, and how well the port selection software perform with your computer OS.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 12-22-2009, 04:50 PM   #2786 (permalink)
jackbauer's Avatar
that cheap enough for ya ?
PCMCIA to RS-232 RS232 Serial DB9 CardBus Adaptor Card on eBay (end time 20-Jan-10 17:49:28 GMT)
www.evbmw.com
Old 12-22-2009, 05:02 PM   #2787 (permalink)
AC-DC enthusiast
mrbigh's Avatar
OMG, all that money? does it realy work?
Old 12-22-2009, 05:18 PM   #2788 (permalink)
mrbigh,
your post comes off as mockery to me. was that your intent?
sorry if my chiming in with my thoughts rubbed you the wrong way.
The Following User Says Thank You to regmeister For This Useful Post:
mrbigh (12-22-2009)
Old 12-22-2009, 06:30 PM   #2789 (permalink)
AC-DC enthusiast
mrbigh's Avatar
mrbigh,
Don't take things so seriously, a quote of humor some times is healthy while I do not end up with a shiner!!
JackBauer did a good research and provided us with a solution to a problem brought up to the board.
As adamj12b previously pointed-up, I also got stuck with a couple of serial/usb dongles, not all of them work smoothly with your computer OS. Finally, I went through 4 of them.
In today's world economics, we do not know what are we buying. This type of merchandise is considered discounted surplus for the throw away society.
If you have to shop for it, make sure of the seller return policies for return/exchanges/refunds and, some times the return shipping is higher than the merchandise.
Old 12-22-2009, 06:31 PM   #2790 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Lol, that's funny
You are allright regs. "I WILL NOT BE MOCKED!!", LOL
Re adapters, the adruino folks have pretty well sorted out usb using the ftdi rs232rl chip, but it is surface mount and needs a driver on windows. There are cables and breakout boards with rs232rl chips on them too.
http://www.hulu.com/watch/19312/satu...ve-you-mock-me
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
