Old 03-12-2010, 03:52 PM   #3151 (permalink)
Joe
Originally Posted by jackbauer View Post
Heatsink peaked at 35c.
Sweet - looks like an ambient temp of around 15 or 20C? Where is your thermistor located relative to the IGBTs?
I'm curious because I have 3 of those IGBTs that adam found. Someday I'll find the time to put a power section together with them and would like an idea of how they'll perform.
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 03-12-2010, 04:00 PM   #3152 (permalink)
EVVette - '71 Chevy Corvette Coupe
Joe,
Hes not using those igbt's that you have yet. These are 1000A single pack ones that hes using. 1 for switch, and 1 for diode.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-12-2010, 04:01 PM   #3153 (permalink)
Joe
Originally Posted by adamj12b View Post
Joe,
-Adam
Ya, i knew that... but it's still a different package and power stage arrangement...
Old 03-12-2010, 04:14 PM   #3154 (permalink)
dave koller's Avatar
Jack did you post a schematic for that igbt arrangement somewhere?
Dave ...
Old 03-12-2010, 05:12 PM   #3155 (permalink)
jackbauer's Avatar
Thermistor is about one inch below the switch device at about mid way. Heatsink is a 250mm square of 12mm thick aluminium. 120mm fan sucks air through the enclosure. Ambient was about 12-13c today. Warmest day yet this year! Dave i posted a little description of the drive system i used for the igbts a few pages back. Very simple stuff but seems to be working a charm.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-12-2010, 06:09 PM   #3156 (permalink)
Originally Posted by Weisheimer View Post
Ludiagsm,
Paul has taken care of the reply, but I did want to say
Way to Go! I watched your video and it sounded nice
and smooth! Keep up the good efforts and you will be catching
up to JackBauer soon.
Cheers
Mark
Thank you Weisheimer .Now i am wandering what mosfets can I use for a low voltage controller for 12volt 100amp. Those Igbt-s that i am using BUP314 are 1200volt 52 amps but they has very high resistance between collector-emitter can you recommend me some good mosfets for low voltage and high amps.
pp:Here in Bulgaria Irf540 and Irf640 has very low cost four euro for 10 mosfets but i must use many of them for 100amp current.
Old 03-12-2010, 06:49 PM   #3157 (permalink)
LOL I remember now it was this "complex" circuit:
Dave ...
Old 03-13-2010, 12:30 AM   #3158 (permalink)
apowers's Avatar
Hi Everyone
I have put a control board together. When I turn the power on the green light comes on but not the yellow one. I tried repowering with the pot all the way the other direction ,no change. So I took the board out and looked for problems. I found 5 resistors with the wrong ohm readings. I removed R13 and replaced it was reading 5.xx K should be 10K. I checked the new one 10K. Put it in but before I soldered it I checked the ohm's and it read 5.xxK ohm's. I took it back out and it reads 10K. Also the 5K pot reads 4.96K until I plug it into the board then it reads 3.9xK . The chip I am using has the old software (the yellow light should blink when it is ok). Where should I look for this problem? Any help sure would be appreciated. Thanks in advance.
Alvin
PS
I had D4 and D5 reversed, I marked the package wrong. So I rechecked the parts list to see if I had marked something else wrong. That did not fix it. But there is a part marked XX a diode, where does that go?
Old 03-13-2010, 02:21 AM   #3159 (permalink)
PaulH
MPaulHolmes's Avatar
Hi Alvin! Once a resistor is soldered in, you can't tell what the resistance is, since you are actually measuring the interaction of a bunch of resistors that are all electrically connected.
The diode that's marked XX isn't needed. I used to add them to the bottom of the board to fix a problem that wasn't really a problem. Just ignore it. I should erase that.
The led isn't flashing... That's not good. It sounds like the software isn't running then. One possibility is a solder bridge? When too much solder crosses over the tiny little isolation ring. I would check all the pins of the atmega8. Maybe something is being shorted to ground?
kits and boards
Old 03-13-2010, 03:06 AM   #3160 (permalink)
jackbauer's Avatar
ludiagsm , This guy would solve your problems in one easy step:
IGBT Modul SEMIKRON SKM400GAL 128D on eBay (end time 07-Apr-10 15:18:49 BST)
www.evbmw.com
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
