Old 03-17-2010, 10:17 PM   #3211 (permalink)
Originally Posted by MPaulHolmes View Post
I think the wiki schematic is up to date for rev. 2C. The australians done made their own improved version, though.
I don't have a good way of posting the schematic in picture form. It's too dang big. any suggestions?! my crap software won't allow it to be saved as a pdf.
you could upload it to http://picasaweb.google.com or some of the photo sharing sites. Alternately you can email it to me and i'll host it for you.
edit: yes you're right the Aussies have a revision 2D of the design... however the link to it is broken.
Old 03-18-2010, 12:33 PM   #3212 (permalink)
Écologue
Thidj LeVert's Avatar
Truce - '99 Ford Taurus
90 day: 23.46 mpg (US)
QuébéCube - '92 Chevrolet Sportvan G20 Beauville
Send a message via MSN to Thidj LeVert
Question My brother, the electrotech
Hi everyone, I beg your pardon for not having read the whole 300+ pages of this important thread but the topic got me very excited. I wanted to know if there is a final revision of a DIY motor controller Schematic or is it still in beta testing? I think I could use my brother into making it and that would be the beginning of my future EV.
Old 03-18-2010, 12:59 PM   #3213 (permalink)
PaulH
MPaulHolmes's Avatar
The revision 2c schematic works well, but you should use the component values listed in the bill of materials on the wiki. A couple resistor values have changed (R15 and R16).
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
Thidj LeVert (03-18-2010)
Old 03-18-2010, 01:23 PM   #3214 (permalink)
Écologue
And this is good for let's say a 110 V AC motor or do I need to search for specific motor? I'm a beginner into this but I think I can manage the info I'll be given.
Last edited by Thidj LeVert; 03-18-2010 at 01:37 PM.. Reason: i read it's for 144V
Old 03-18-2010, 01:53 PM   #3215 (permalink)
PaulH
Well, this controller is for a series wound DC motor. It can use anywhere from 0v up to about 144v. If you change the mosfets/diodes/capacitors on the power section, you can have the voltage range go up just about as high as you want.
kits and boards
Old 03-18-2010, 02:54 PM   #3216 (permalink)
E-car - '84 Toyota Corolla LE
Hi Mike and Adam, I'm getting oh so close. If only there weren't so many interruptions. I'm teaching my daughter to drive, and she's looking for a job. Meaning that I have to ride with while she goes around applying. Then I got a ticket for a headlight out and after 2 days of driving around well over 40 miles, I'm getting closer to the end of that..... then having to work for a living.... oops I digress..
Controller: power on LED's on steady, Realterm up and connected to the com port I have no communication and cannot see program. WH-@#$@%!!!
Sorry to bother you again.....
The controller is coming along very nicely and I wouldn't change anything. I rather build my own controller and know everything about it than fork out tons of $$$$ again for something that I can't fix.
Thanks guys for all your hard work.
Old 03-18-2010, 02:56 PM   #3217 (permalink)
PaulH
Do you have the serial port plugged into the computer? Is com1 or whatever being used by another program?
kits and boards
Old 03-18-2010, 02:58 PM   #3218 (permalink)
I'm connected but cannot use com 1 as a choice from Realterm, Its a USB connection allowing com 3
Old 03-18-2010, 02:59 PM   #3219 (permalink)
I'll go back through the laptop and see where Its set right now. Da I should have tried that
Old 03-18-2010, 03:04 PM   #3220 (permalink)
I think I can choose another com port. I'll be right back.... OOOHH SOOOOO close
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
