Old 04-21-2010, 05:48 PM   #3351 (permalink)
Joe
Originally Posted by bones007 View Post
I have a question about pre-charging the controller. Is there any reason why we shouldn't just put a resistor in parallel with the main contactor and just leave it there. If we do so then the controller caps will always be charged up and there is no need to wait some time before closing the contactor.
Aside from the other reasons mentioned above, I think an important reason is to protect the controller during charging. My 144V pack will reach 183V during equalization. While everything in the controller is rated for 200V, there's no need to expose it to high voltage. A capacitor's voltage rating can decrease with age. A malfunctioning charger can push the voltage past your set point. If your charger isn't isolated, voltage spikes from the AC line can fry your controller components too.
so, overall it's a cheap way to avoid some failure modes while making things a little safer.
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
Old 04-22-2010, 02:44 PM   #3352 (permalink)
jackbauer's Avatar
A new era of testing begins
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 04-22-2010, 02:54 PM   #3353 (permalink)
PaulH
MPaulHolmes's Avatar
holy cow. Holy cow!!!!! On a separate note, I watched the Secret of Roan Inish yesterday. IT was really good.
kits and boards
Old 04-22-2010, 03:09 PM   #3354 (permalink)
jackbauer's Avatar
It gets better
This is a shot of the gate emitter of number 4 igbt. I think i had the coupling set wrong. Not bad for a "cheap" scope
ID:	5972   Click image for larger version
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
MPaulHolmes (04-22-2010)
Old 04-22-2010, 03:40 PM   #3355 (permalink)
dave koller's Avatar
Ah, now do you believe in Selkies Paul?
Dave ...
Old 04-22-2010, 04:13 PM   #3356 (permalink)
PaulH
hahahaha yes! I believe! I also believe that little boy would have sunk in his little raft if he got much older! hahahaha
I'm almost ready to test the bms and charger! super super super close!
kits and boards
Old 04-24-2010, 10:36 AM   #3357 (permalink)
jackbauer's Avatar
I promised Adam i'd hook the logic analyser up to the controller. Quite tedious but i got there. Still don't quite know how to use the thing!
Also did a few measurements using the new dso on the 1000amp controller. Noticed some ringing at over 500khz measured across the switch. hmmmm .....
I like old style test gear. Nothing like hearing the big fans running up to speed and waiting for the display to warm up! These days its all colour oled displays and fancy self tests. Not the same
ID:	5974   Click image for larger version
ID:	5975   Click image for larger version
ID:	5976   Click image for larger version
ID:	5977   Click image for larger version
www.evbmw.com
Old 04-24-2010, 12:21 PM   #3358 (permalink)
LOL - Been there squinting at the CRT to say "was that a glitch?" ....
Dave ...
Old 04-24-2010, 03:42 PM   #3359 (permalink)
hey today i have first test run on 48 volts in the beginning i have 30km/h on second gear and after that 38km/h on 3-th the batteries was't charged properly but after 2 km ride i tried to take this video :
The Following User Says Thank You to ludiagsm For This Useful Post:
deodeo (03-26-2012)
Old 04-25-2010, 10:43 AM   #3360 (permalink)
It seems that i need different setup those 6 inch motors are very weak ,i need to bay powerful one 9 or 11 inch like those AC motors, DC motors, Grinders - Kostov Motors
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
