Old 10-30-2010, 12:22 PM   #3941 (permalink)
Mark Weisheimer
Darlington Power Modules
Originally Posted by snakub View Post
Does anyone have a board lying around maybe you could do some testing like I did and tell me what measurements you got?
My spare board was not a populated as I thought....
But I'll share some thoughts.
I still think the issue is in the control board here are some oddities that I found while measuring components while they were on the board.
I would take the control board to the bench and test it.
Do you have an o'scope available? It would be quite helpful.
If you can't test it there, mail it to Columbus and I'll promptly test
it and send it back to you.
D8 and D9 are not backwards but I couldn't test them properly either when I measured them with the multimeter positive to positive negative to negative I got 7.3k both ways.
Your multimeter should have a diode test. It will read about .7v one direction and 0L when the leads are reversed.
The multimeter has to provide at least enough voltage to overcome the diode threshold. If you have already tested it with that scale, then the diodes are faulty.
They are not located in a place where I would expect them to fail from an external fault, so I expect them to be OK.
R18 measured 2.2k but I looked at it and the color code was definitely Orange black red 100 percent sure.
It is probably fine, the other components are causing that reading.
Maybe I have to take these parts off to get a proper measurement?
Yes, in theory, but other than your diode measurements, they seem
OK to me.
Old 10-30-2010, 07:59 PM   #3942 (permalink)
Modding for Eris
Thalass's Avatar
SilverCivic - '08 Honda Civic
90 day: 28.69 mpg (US)
Awesome stuff, Jack.
Making do with a Honda Civic. Tesla Model 3 reserved. Still kinda want an SVX for fun, though.
Old 10-31-2010, 10:31 AM   #3943 (permalink)
Custom EV Builder...
Originally Posted by jackbauer View Post
wakinyantanka can you post the part number?
Yes it's a Hitachi MBN1200GS12AW 1200v 1200A module. I am actually looking at two of them.
Thanks.
Old 10-31-2010, 10:51 AM   #3944 (permalink)
jackbauer's Avatar
The problem with such large slightly dated modules is not their ability to handle power but their ability to switch fast. Comparing the hitachi module to the fuji 1mbi800U4B-120 that i'm using in the car right now:
Fuji:
ton typ = 0.32us
toff typ = 0.41us
Hitachi :
ton typ = 0.8us
toff typ = 1.4us
So from the above switching losses would be quite high.The hitachi also has a higher gate capacitance at 112nf vs 90nf for the fuji. this would require more gate drive.
I'm not saying it won't work just that its not all about the Vce and Ic when it comes to igbts.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
Tired2 (11-01-2010), wakinyantanka (11-01-2010)
Old 11-01-2010, 08:44 AM   #3945 (permalink)
Fuji:
ton typ = 0.32us
toff typ = 0.41us
Hitachi :
ton typ = 0.8us
toff typ = 1.4us
Thanks Jack that's what I needed to know. What about these types of igbts: EUPEC 1U/1200A/1200V IGBT Module, FZ1200R12KL4C ?
Old 11-01-2010, 12:30 PM   #3946 (permalink)
PWM and Current Reset question
Paul, or anyone else who might know...
I built my over current section for my "spin off" of the ReVolt I'm building... I have tested the circuit on a breadboard, and it works with my 3.3v conversion and logic. I'm at the point where I need to feed in a PWM signal and simulate an over current condition, then start toggling the reset pin to turn the drives back on.
My questions:
1) I need to toggle the pin from low to high for a small amount of time to reset the overcurrent condition... what is the ReVolt's phase relationship between PWM and the overcurrent clear signal? Also, when in the PWM's cycle do you toggle that pin, and how long does it stay high? (I imagine the time is not critical, just that the NAND has time to react)...
It is possible the reset is not PWM aligned in any meaningful way... It seems like it would work at any phase, but you might cut a duty cycle in half when it re-enables the gate drive.
2) On a related note, what have you found to be the amount of "dead time" that you leave the PWM output off for? I seem to remember reading it a few times, but I'm not sure what the final value was set to. The dead time should be long enough to let the current fall back below the threshold, but short enough to not make the motor action jerky.
Thanks.
Old 11-01-2010, 01:49 PM   #3947 (permalink)
jackbauer's Avatar
wakinyantanka , again just looking at ton and toff in the datasheet at 0.54us and 1.05us respectively you can see its a much better choice. Its a *little* long in the turn off but i'd live with it..........
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
wakinyantanka (11-02-2010)
Old 11-02-2010, 06:16 PM   #3948 (permalink)
PaulH
MPaulHolmes's Avatar
I made a driver board based on the BG2A board from Powerex. I haven't sent it in yet. It can drive dual 1200v 1200amp igbts no problem. Powerex says it works for anything they sell. It's just a bit over $100 in parts (including the price of the board). There are 2 drivers/power supplies. Here's a picture of it:
It drives to +15v and down to around -8v for shutoff.
This would work well for mosfets too. It might be a better choice for the SR controller, due to the absurdly awesome drivers.
kits and boards
Old 11-02-2010, 08:12 PM   #3949 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Thumbs up SR controller
OMG!!!
we are getting closer to the SR controller board completion.............
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 11-02-2010, 08:23 PM   #3950 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Paul, do you care to share the part numbers of U1, U2 and the 2 large integrators in the right hand side of the board so I can read the Tech spec's about them?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
