Old 11-24-2010, 06:36 PM   #4051 (permalink)
Been a while, but I finished my controller and it works pretty well. I used pcbs from Paul and bought the bits from Ian Bartie in Australia. He supplies a copper heat spreader bar! My case is folded from 3mm Al with a big lump of finned heatsink bolted to it - eight bolts in two rows of four. One row is the bolts through the heat spreader bar and the other row is four bolts from inside tapped into the heat sink base.
It powers two Advanced L91 motors connected in series and driven by 45 x Li cells also in series giving 144v. Pushes a 1988 BMW 318 (E30) along the road with direct drive ie no clutch or gearbox.
Top speed is just 100 kph and acceleration from 0 to 80 kph is about 12 seconds. I did have the motors connected in parallel at one stage and that gave a top speed of about 130 kph but the acceleration was very snail like. So, not enough torque (current) for good acceleration with parallel connection and not enough volts for good top speed with serial connection. Have to figure out a switch!
It draws 170A from the battery at full speed.
RTD Explorer tells me the heat spreader temp sits around 43 - 45 deg C during continuous operation at about 50 - 70 kph (depends on the speed zones). Outside temp was 22 deg C.
Done just on 1000 kms with it now and I get about 120 kms before the volts drop below 135.
I'd put a picture here if I knew how!
Old 11-24-2010, 07:34 PM   #4052 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
harlequin2
great news about the Cougar type controller you build; you are among many other satisfied DIY Kit builders and isn't great the RTD explorer? thanks to adam12
you can copy pictures from a folder of your computer while posting something, look for a button called " Manage Attachments " and it will be self explanatory.
Good luck and keep the pictures coming..
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 11-24-2010, 08:29 PM   #4053 (permalink)
Thanks for the advice, mrbigh. So, if it worked, here's a picture of my controller!
Name:	Cougar Controller1.jpg
Old 11-24-2010, 08:46 PM   #4054 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Thumbs up Newest harlequin2 controller
Yeah, it made it to the world for everyone to see.....
Old 11-24-2010, 09:13 PM   #4055 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Looks solid! Nice job!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 11-25-2010, 04:25 AM   #4056 (permalink)
Series to parallel shifting can be done with contactors and is common in drag racing. The Killa cycle uses this for example. A bit of googleing should reveal the setup. Congratulations on getting on the road.
Greg
The Following User Says Thank You to Greg Fordyce For This Useful Post:
mpgmike (01-19-2022)
Old 11-29-2010, 12:40 PM   #4057 (permalink)
EVVette - '71 Chevy Corvette Coupe
Hello Everyone,
A few weeks back there was talk about a group buy for the VLA-500-01 Drivers. I offered to do a group buy for these. Currently I have 1o called for. The goal is 25 to drop the price from $43.66 to $37.76. If anybody else is interested, Please let me know.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 11-29-2010, 05:04 PM   #4058 (permalink)
Custom EV Builder...
Originally Posted by adamj12b View Post
Hello Everyone,
-Adam
Are these the same drivers we have been talking about? These are for the IGBT set-up, correct. If so, count me in for 1.
Old 11-29-2010, 08:20 PM   #4059 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Originally Posted by adam12 View Post
Hello Everyone,
-Adam
Adam
Can you please put an add in the classified section to promote sales count?
Thank you
Old 11-29-2010, 09:15 PM   #4060 (permalink)
Computer/EV enthusiast
So, does this mean we'll see Paul's very own display system built into the next controller? Complete with spiffy graphics of lightning bolts and tires burning rubber on the controller control panel?
On the topic of displays, laptop displays have pretty weird and flimsy connectors and aren't exactly the best choice. At least the displays I've worked with. Benjamin J Heckendorn has used everything from PS1 travel screens to digital picture frames to dirt cheap off brand LCD monitors in his projects and just recently did a hack with a rotating laptop screen. If someone somewhere has found a way to use the cheap touchscreens from digital picture frames for other hacks that would be a great way to tinker with controller data and settings on the fly.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
