Old 04-28-2011, 06:44 PM   #4671 (permalink)
PaulH
MPaulHolmes's Avatar
We do need to build paul a new coupler!!! Weird. That was all caps, and it made it all lowercase.
kits and boards
Old 04-29-2011, 02:52 AM   #4672 (permalink)
EV Connoisseur
Joehooo..
Just wanted to share that i've got my 500A controller working... on a light bulb.
I'll plug it into my EV this weekend..
Old 04-29-2011, 03:07 AM   #4673 (permalink)
PaulH
Hurray!!! Wouldn't it be hilarious if some guy had a motor controller in his room, so that each time he wanted to "set the mood", he dimmed the house lights by twisting the throttle? hahaha.
Baby, I love you... Let me turn on the 12v auxiliary battery, honey, so that I can dim the lights. hahaha.
kits and boards
Old 04-29-2011, 03:09 AM   #4674 (permalink)
EV Connoisseur
"set the mood" .. he he he..
Old 04-29-2011, 07:15 AM   #4675 (permalink)
EV Connoisseur
Need help on labeling
Hi,
Now i've got it together and tested it on an lightbulb i'm starting to doubt that i've labeled the bus bars correct. On some pictures of cougar controllers the M- and B- are the other way around.
See picture.. is that correct?
http://blog.evombouw.nl/image.axd?picture=image_41.png
p.s. I've tried to look it up in the schematic.. but the link in the wiki is broken.
Old 04-29-2011, 08:36 AM   #4676 (permalink)
PaulH
The picture looks correct to me!
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
flores (04-29-2011)
Old 04-30-2011, 10:47 AM   #4677 (permalink)
PaulH
I put together a controller for me! hurray! I have one now. It's one of the new ones too, so I can test it a little more wild and crazy. Also, I just saw the best movie in history. I highly recommend it. It's called "Mega Shark Vs. Crocosaurus". It sounds like it wouldn't be very good, but you should see it on Netflix. ONe of the best movies ever made.
kits and boards
Old 04-30-2011, 11:08 AM   #4678 (permalink)
jackbauer's Avatar
Finally done with the bike controller. Now just need to dig out that old starter and do a few 12v tests. Then unleash it on the twin motors
I fitted 1R 1W emitter resistors to the igbt modules. This is to allow for better current sharing according to that powerex app note.
ID:	8257   Click image for larger version
ID:	8258   Click image for larger version
ID:	8259   Click image for larger version
ID:	8260   Click image for larger version
ID:	8262   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
LouMan (04-30-2011), mrbigh (04-30-2011)
Old 04-30-2011, 11:41 AM   #4679 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
are U still using the old stile controller?
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 04-30-2011, 11:49 AM   #4680 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Have a problem....
I was in the mood of assembling the Malexis current controller and found that the silk screen in the PCB is unreadable.
Then I downloaded the Wiki files for the same PCB but I'm unable to open these ones with the GNU Image Manipulation program that come attached to the .GBR files. I tried also the DesignSparks program with no luck at all.
I can't read the parts positions on the PCB.
Any help?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
