Old 07-14-2011, 01:58 AM   #4931 (permalink)
hi Paul,
thank you very much the PCB and components were arrived today. I am going to populate and solder them this week end, hope everything goes well....
thanks again,
Kukuh
JAKARTA
Old 07-14-2011, 11:49 AM   #4932 (permalink)
jackbauer's Avatar
Well , spent most of the day playing about with resistor values and configs. Hit on one that gave the best compromise between ringing , overshoot and transition time.
Tests pefromed:
1)With coolant temp at 25C , took the controller to 510amps for 60 seconds. Coolant at 29C at end of test. No air flow through radiator. Simulate hill climb.
2)With modest (estimate 20mph) airflow through 3/4 of the radiator. Throttle locked at 210 amps for one hour. Heatsink temp leveled off at 49C after 40 minutes. At one hour temp difference between front and rear of heatsink at 3C. One minute power excursion to 510amps. Temp at 52C at end of test.
So i figure enough testing. Gonna install it in the car tomorrow.
ID:	8989   Click image for larger version
ID:	8990   Click image for larger version
ID:	8991   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
The Following User Says Thank You to jackbauer For This Useful Post:
thingstodo (07-24-2011)
Old 07-14-2011, 03:12 PM   #4933 (permalink)
dave koller's Avatar
Jack
This may be off base, but have you tried small ferrite beads on the base end. It works for my bigger robots that run at 15khz. - quenches the ringing.
Dave ...
Old 07-14-2011, 04:48 PM   #4934 (permalink)
jackbauer's Avatar
Dave, you mean beads on the gate drive leads or the power leads?
www.evbmw.com
Old 07-14-2011, 05:15 PM   #4935 (permalink)
Gate Jack.
Dave ...
Old 07-14-2011, 05:17 PM   #4936 (permalink)
jackbauer's Avatar
hmmmm.........interesting. Thanks Dave
www.evbmw.com
Old 07-14-2011, 09:30 PM   #4937 (permalink)
That would be an interesting test. In theory it should not work as you are adding inductance, it would smooth off spikes but possibly induce ringing. Still there is nothing like a bit of live testing.
Old 07-14-2011, 10:11 PM   #4938 (permalink)
It seems to suppress the ringing (med and high frequency) and snub the oscillation from longer lead inductance up to the resistors. Like I said, just a hunch. I have some longer traces from my opto drivers and I place the beads as close to the base of the inputs on my H-Bridge as I can get them. Without them I get ring and oscillation and messed up PWM signal.
Dave ...
Old 07-16-2011, 10:17 AM   #4939 (permalink)
jackbauer's Avatar
Controller is in. Still have to hookup the coolant. Got the rad , pump and bottle installed then realised i didnt have one piece of hose. 'course the auto store was closed. Did a little test drive with no coolant. No probs so far. Fingers crossed.
ID:	9007   Click image for larger version
www.evbmw.com
The Following 3 Users Say Thank You to jackbauer For This Useful Post:
LouMan (07-26-2011), MPaulHolmes (07-16-2011), thingstodo (07-24-2011)
Old 07-16-2011, 04:24 PM   #4940 (permalink)
Paul great work I cannot wait to keep reading about it.
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
