Old 01-14-2013, 01:59 PM   #5961 (permalink)
Originally Posted by MPaulHolmes View Post
That's a good point. The controller will cut out if throttle goes out of range, or if 5v power or 12v power drops out of range.
Paul, I just got called out of town on an emergency, so I can't post the screenshot of the software, nor can I test the power to the throttle.
I'll do both once I get back.
Thanks!
Old 01-17-2013, 03:56 PM   #5962 (permalink)
PaulH
MPaulHolmes's Avatar
We just now got the 5 cubic yards of cement poured and leveled for the shop. PHEW!! That was a job. My wife was a huge help, dragging the 2x4 across to level it. Then I'll have a place to put the mill. Hurray!
kits and boards
Old 01-17-2013, 04:28 PM   #5963 (permalink)
I'm attaching a file of a screenshot of RTD Explorer when I slowly accelerate and then loose all power. I take my foot off the accelerator when the van stops moving forward, that's why you see everything just DROP.
@227-228 is where the power drops, but my foot is still on the accelerator and a second later between 228-229 is where I take my foot off the accelerator.
Any ideas?
Name:	1-17-2013 4.13.24 PM.png
Old 01-17-2013, 04:47 PM   #5964 (permalink)
Do you have a BMS that may be interacting with the control system (changing throttle signal or opening a contactor or something like that)?
It appears that when you say you lose power, PWM spikes from less than 20% to maxed at 100%. At the same time your current drops rapidly.
Old 01-17-2013, 05:18 PM   #5965 (permalink)
Nothing fancy, just 10 individual voltmeters attached to each pair of batteries.
Also an ammeter on the battery pack. V meters and A meter have been attached for at least 100 miles without any problem, I don't see why they would start something weird now.
Old 01-17-2013, 05:28 PM   #5966 (permalink)
Here's another screenshot of two episodes. The first (2085) one I kept my foot on the accelerator longer (about 2 or 3 seconds) to make it clearer. The 2nd episode I started slowly accelerating @2094, the power went out and I tried feathering it back so it would "power up" again. You can see where I lost power at 2100, got it back, and lost it again between 2101 and 2102.
I should note that this whole time I'm in my driveway, with the emergency brake on a bit to keep me from moving far before I create the episodes. I can really only be in 1st and reverse. In 2nd, too much is being asked of the bus and it cuts out almost immediately. Normally, though, I drive in 2nd 95% of the time in the city where I rarely go above 40 mph
I really appreciate the help. I'd be lost without it.
Name:	1-17-2013 4.44.12 PM.png
Old 01-17-2013, 05:35 PM   #5967 (permalink)
Could you post screenshot of 'controller settings' area of rtdexplorer?
Old 01-17-2013, 08:00 PM   #5968 (permalink)
Sure.
Um... how do I do that?
Old 01-17-2013, 08:55 PM   #5969 (permalink)
hm, IIRC if you type "config" in RTD you'll get list of all parameters, then use PrntScrn key to capture screenshot to your clipboard...
Old 01-18-2013, 07:37 AM   #5970 (permalink)
;P better yet alt+PrntScrn will let you capture only the window in focus. (XD A random chime in, but hey, handy hotkeys are handy)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
