Old 02-15-2013, 07:41 AM   #6011 (permalink)
Originally Posted by MPaulHolmes View Post
Can you read the part number for U6 and U7?
u6 A4504 1139
u7 mic4452yn 1222
Z
Old 02-15-2013, 07:51 AM   #6012 (permalink)
Hmmm.. now I can see what could be the problem!
on the BOM U7 is MIC4451YN i've got MIC4452YN....
Thanks Paul, probably I couldn't find it until the end of my life.
Z
Old 02-15-2013, 07:59 AM   #6013 (permalink)
PaulH
MPaulHolmes's Avatar
AHA! YAHOO!!!!! mic4452 is a NON-inverting driver, whereas mic4451 is an inverting driver.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
zsnemeth (02-15-2013)
Old 02-15-2013, 08:58 AM   #6014 (permalink)
Yeppp!
Surprise, surprise.....IT'S ALIVE!!!!!!
I've been checking the board over and over.. and couldn't spot it. What a moron....!
Z
Old 02-16-2013, 11:51 AM   #6015 (permalink)
Update:
I finally got some time to work on the EV. Now, the EV won't even roll out of the garage at a low speed. It seems like whatever is happening is getting worse. It *starts* to move and then stops. It rolls a tiny bit, maybe half an inch, before the episode starts happening.
So I took the two cables from the controller off the motor and with the controller on and my hand mechanicaly controlling the pot, I measured the volts going to the motor. It put out way more volts than I expected very quickly. It went from 0 to 90v within a very small movement of the pot arm.
But I took that to mean that the controller was responding appropriately.
So I dropped the motor (easier said than done) and with it firmly secured, I used jumper cables to run 6v to it and then 12v to it from my battery pack. At 6v I could barely stop the motor from turing with my hand. 12v was too much to stop, and it sounded like the RPMs were going up and up if I left the cables attached.
There's nothing obvious out of place on the motor, but I don't have alot of experience looking at electric motors so I could be looking at something that's out of place but I don't know it.
Any suggestions of what I could/should test next and pointers on how to do it?
Thanks!
Originally Posted by jyanof View Post
In both graphs you posted, and all 3 events shown in the graphs, the same thing happens:
1 - motor current tracks the command current at first: notice the blue and red lines are on top of each other at first.
2 - then, motor current falls and matches the battery current (light blue line). also, the pwm line (pink) jumps to 512 which is wide open. these all agree with each other - when the mosfets are full on, the motor current and battery current will be the same
this is very odd behavior, especially considering that the vehicle slows down. in normal driving, you will likely never reach wide open pwm, and if you do, it's at a high speed and high current.
i'd say your controller is working correctly, but something is wrong on the motor end. the controller is outputting power, but it's not going to the motor.
I think you mentioned your battery voltage is something like 120v and the charts show that they're pushing about 100 amps when the event happens, so that's 12 kW that's just going into heat somewhere!
it really sounds like a motor problem, maybe something is shorting the field or rotor winding so you're only energizing one set of windings? or, a loose connection? maybe it's fine at first, but as the motor heats up, things expand and cause something to short out? or, maybe it's speed related?
Old 02-16-2013, 12:23 PM   #6016 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Is your potentiometer the right value? and connected correctly?
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 02-21-2013, 09:41 PM   #6017 (permalink)
Hi Paul
After I replaced the MOSFETS my controller was fine
Took the car up to Dunedin for certification
Drove well - lots of go - took it up to 100Kph on the "motorway"
passed certification
I am still waiting for the cert plate to get it on the road but I intended using the car at the 1/8th mile drags this Sunday
THEN
I went out to the car to move it
12v switch and first contactor OK
pre-charge - light stayed on???
switched the "forwards contactor OFF
pre-charge light went out
switched on second contactor
switch on reverse
BANG --- car jerked backwards - smoke came out of vents
I will strip it down but it seems to have eaten its MOSFETS
ID:	12513   Click image for larger version
ID:	12514   Click image for larger version
Old 02-21-2013, 10:15 PM   #6018 (permalink)
Taken it to pieces
all of the MOSFETs look damaged
Everything else looks OK
As I am a mechanical guy I am not sure if I have toasted anything else
I will have to give up on the drags this weekend
Where is the 1000amp controller at?
If I replace the MOSFETS that is a fair chunk of the cost of a new kit - and I don't know if I have damaged anything else
Is this a good time to upgrade and buy a 1000amp kit?
Old 02-21-2013, 11:01 PM   #6019 (permalink)
PaulH
Was that a board etched with a mill? Was it a standard 500amps?
kits and boards
Old 02-22-2013, 12:08 AM   #6020 (permalink)
Hi Paul
It was a std 500 amp controller - the power board looked like it had been milled
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
