Old 06-26-2014, 05:36 PM   #6571 (permalink)
PaulH
MPaulHolmes's Avatar
What are the throttles of you 3? Well, of Flores and Duncan? So far I have 5k meaning zero throttle, and 0 meaning full throttle for jedsmd. Are the other 2 just 0-5k, where 0 means zero throttle, and 5k means max throttle? Also, do flores or Duncan have a contactor coil in line with the throttle? That's touchy business when dealing with current control. You really don't want the PWM to be ramped up to 100% while current feedback stays at zero, all because the contactor that is enabled through the throttle hasn't turned on yet.
kits and boards
Old 06-26-2014, 06:16 PM   #6572 (permalink)
PLUGnGO
jedsmd's Avatar
And it has arrived!!!
There are lots of wires hanging out the low power end, so I'm trying to identify them:
Mediam gauge twisted pair red/black - - 12vdc
light gauge twisted pair red/black - - idiot light
light gauge twisted pair red/green no connectors -- ??????
light gauge twisted pair green/green no connectors -- ??????
5 conductor ribbon -- Pickit 3
serial port -- Flores' web device
light gauge twisted blue/white -- ??????
The power stuff looks pretty straight forward.
Old 06-26-2014, 07:30 PM   #6573 (permalink)
Hi Paul
I have 0-5K with 5k being full throttle
No contactor -
But I do have a brake light switch that shorts the throttle pot when I brake
I would like a fast throttle response - 0.1 seconds (ish) to full
Really looking forwards to this - even if it is damn cold out there just now
Old 06-27-2014, 12:04 AM   #6574 (permalink)
PaulH
This is only for jedsmd, as I ran out of some of those colored wires:
Wiring for 1000amp controller:
Rightmost blue & white twisted pair (J6):
J6 blue wire is main contactor ground wire. Don't connect the contactor ground wire to anything other than J6 blue wire.
J6 white wire is main contactor coil +24v. Yes, 24v. If you currently use a 12v coil, I'd just not bother with J5 and J6.
J5 (next twisted pair over to the left from J6. Blue and white again):
J5 is for turning on the precharge relay, which is NOT a part of the controller. J5 blue connects to the precharge relay ground.
J5 white connects to the precharge relay +24v.
Note: If you don't want to be bothered with J5 and J6, just don't connect them, but you should still take care of precharge and closing the contactor yourself.
The next twisted pair (black and blue) to the left, J4, is the +24v auxiliary supply input. It comes from the DC-DC that's inside the controller, mounted
to the top of the enclosure. Blue is 24v, and black is ground.
J3 is valet Mode. The pin on the left needs to be connected to ground (possibly through an on/off toggle switch).
The pin on the right need to be connected to the car's auxiliary +12v supply. You could put the on/off switch on either line.
The next connection over is Temperature. That's already connected to a thermistor inside the controller.
Throttle (connected on the bottom) is the next connection to the left after Temperature. 2 wire. No polarity.
The black and red twisted pair sticking out (18 gauge wire) is where you connect the 12v auxiliary supply.
The ribbon cable is for programming the microcontroller with the pickit 2 or 3. It plugs into the PICKIT as follows:
black - PIN 1, which is MCLR (indicated with an arrow on the pickit 3)
white - PIN 2, which is Vdd Target
gray - PIN 3, which is Vss (ground)
purple - PIN 4, which is PGD
blue - PIN 5, which is PGC
UNUSED - PIN 6.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
flores (06-30-2014), jedsmd (06-27-2014)
Old 06-27-2014, 02:31 AM   #6575 (permalink)
PLUGnGO
jedsmd's Avatar
I will connect the j6 wires to a 24volt relay to isolate them from the main contactor which is 12volt.
I normally connect the precharge resistor directly from the battery pack to the controller so that the capacitor bank is always at pack voltage.
Thank-you
Old 06-27-2014, 03:25 AM   #6576 (permalink)
EV Connoisseur
If it's the same as the 500A and the 1000A, it will work for me.. no contactor
Old 06-28-2014, 01:59 AM   #6577 (permalink)
Joe
We want pictures!
ReVolt AZ testing thread:
http://ecomodder.com/forum/showthrea...ting-9325.html
The Following User Says Thank You to jyanof For This Useful Post:
MPaulHolmes (06-28-2014)
Old 06-28-2014, 10:44 AM   #6578 (permalink)
PaulH
OK, Duncan's is basically done. I need to hook it up to my golf cart to test it out though. Everything takes so dang long. I'll be sure to take pictures, and to also only go outside after 7pm. It's hot down here! OK, I just checked, and the golf cart has 3 flat tires. I'll see if pumping them up lets them hold the air for a while.
kits and boards
Old 06-30-2014, 01:54 AM   #6579 (permalink)
PaulH
Here's a picture of our first test drive. 12v with full throttle set to 100 motor amps. That bugger glided like a ninja. I had no idea that golf cart to be so darn ninjalike. The PI loop seemed to converge fast. I felt no oscillations.
kits and boards
The Following 3 Users Say Thank You to MPaulHolmes For This Useful Post:
evimarn (06-30-2014), flores (06-30-2014), jedsmd (06-30-2014)
Old 06-30-2014, 11:32 AM   #6580 (permalink)
PaulH
And now the side view!
And a video that hopefully works:
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
flores (06-30-2014)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
