Old 07-16-2014, 05:54 PM   #6691 (permalink)
EV Connoisseur
Yeah.. like these guys
The Following 2 Users Say Thank You to flores For This Useful Post:
MPaulHolmes (07-16-2014), thingstodo (07-17-2014)
Old 07-17-2014, 12:13 AM   #6692 (permalink)
PLUGnGO
jedsmd's Avatar
Originally Posted by MPaulHolmes View Post
To change the time to 4.6 seconds before the contactor closes (this is only useful if you are precharging during the 4.6 seconds. If you just have the capacitors charged all the time, you could set it to something NONZERO but small, like 1. if it's set to 0, it's disabled, and I think it won't close the contactor. I'll have to doublecheck that though):
pc-time 46
save
That applies to me I will give it a shot.
Old 07-17-2014, 12:42 AM   #6693 (permalink)
PLUGnGO
jedsmd's Avatar
Test run today with revised max current (800 amps) and accelerator dead zone (6%). Both setting are good!
Really nice -- Very smooth fine control for parking, no valet switch will be needed.
Acceleration is also very smooth and controllable.
8Khz whine is quite noticable not quite annoying but reminds you that you are driving an EV.
Drove about 15 miles with some stop and go and some hills. Base plate temperature rose to 150 degf. Any thoughts on 150 degf? At what temperature does it become a problem?
The Following 3 Users Say Thank You to jedsmd For This Useful Post:
flores (07-17-2014), MPaulHolmes (07-17-2014), thingstodo (07-17-2014)
Old 07-17-2014, 01:29 AM   #6694 (permalink)
PaulH
MPaulHolmes's Avatar
150degF is 65degC. That's not too bad. The thermal cutback comes on at 75degC, and smoothly reduces max throttle until 85degC. The capacitor can be at 105degC all day for years. However, a finned heatsink would not be a bad idea. I was warned by Otmar (zilla) that it would be necessary, possibly with a fan, or liquid cooling. He made IGBT module controllers in the 90's and they were unreliable due to heat. The caps could have failed, which won't happen in our case. It could have been the IGBTs though. Do you want to try the spread spectrum switching? Or we can try higher frequency too (inaudible), and see the affect on heating.
kits and boards
The Following 2 Users Say Thank You to MPaulHolmes For This Useful Post:
jedsmd (07-17-2014), thingstodo (07-17-2014)
Old 07-17-2014, 01:47 AM   #6695 (permalink)
PLUGnGO
jedsmd's Avatar
I'm a little confused here, I thought I had the spread spectrum already? If not I would certainly like to give it a try.
I do have a heatsink It just laziness that it is not in there now.
Old 07-17-2014, 01:56 AM   #6696 (permalink)
PaulH
Nope, no spread spectrum switching on your current hex file. Just plain old dumb 8khz. Let's try it. I'll send you the spread spectrum hex file tomorrow morning.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
jedsmd (07-17-2014)
Old 07-17-2014, 10:12 AM   #6697 (permalink)
PaulH
Be gentle with your driving at the moment. I had the temperature protection disabled by mistake. I'm almost done making several changes. It should be ready in a few minutes.
My wife just got done doing our state online taxes, so NOW it should be ready in a few minutes!
BTW, if there is a single hardware overcurrent event, the controller will shut down, and you will have to cycle power. It would be preferable to clear the fault after some amount of time, but just for now during debugging I thought it would be best to shut it all down if that happens. You don't want to keep clearing hardware overcurrent faults if they happen in rapid succession. That blew up one guy's controller a couple years ago.
One thing I'm very curious about: Will the driving smoothness be affected by the spread spectrum switching? The period keeps changing, which may complicate the PI loop convergence. But it might be OK. One test is worth a 1000 theories, as they say. haha
kits and boards
jedsmd (07-17-2014)
Old 07-17-2014, 03:13 PM   #6698 (permalink)
EV Connoisseur
I got the rs232 shields today.. did some research and decided that I'd better take a raspberry pi.. haha...
More on that later..
The Following User Says Thank You to flores For This Useful Post:
Old 07-17-2014, 07:20 PM   #6699 (permalink)
PLUGnGO
jedsmd's Avatar
Just took it for a 4 mile test run with the spread spectrum software. Drive-ability was unaffected. It was just as smooth as with the 8 khz.
The sound was quite different instead of a whine it now makes a hiss. The best I can describe it is the truck sounds like it is leaking air. It is about the same loudness as the 8khz whine but it blends in with the background noise and is much easier to ignor.
It didn't seem to be heating any different than with 8 khz pwm but data logging and more driving would be required to be sure.
Jerald
The Following 2 Users Say Thank You to jedsmd For This Useful Post:
Old 07-17-2014, 11:12 PM   #6700 (permalink)
PaulH
We can also try a higher frequency (say, 15KHz) if the hissing gets annoying, but there will be more heat loss. Instead of spread-spectrum, I wonder if we could do the Jetson's car sound? I bet we could. It might take quite a bit of memory, but we have the space.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
