08-07-2014, 08:01 AM
#6791 (permalink)
PaulH
Oops, I forgot. I also don't know what any of the stuff is that you wrote in the last comment. But I'm sure its a good idea. So, YES. Make one of those things that you just said. Haha.
08-07-2014, 08:02 AM
#6792 (permalink)
EV Connoisseur
I was referring to this:
Originally Posted by flores
Paul,
Is it possible to create a 'rtd' command, that would spit out one line of rtd data on request? in addition to the rtd-period.
I'm having a hard time with the continuous stream of data on the raspberry a.t.m. and such a command would help me a lot.
thanks.
08-07-2014, 08:03 AM
#6793 (permalink)
EV Connoisseur
Oh .. I get it.. github.. it is a source code repository thing..
08-07-2014, 08:04 AM
#6794 (permalink)
EV Connoisseur
And that would only work if everybody that works on the firmware actually uses it.. that means you have to use it primarily
08-07-2014, 08:27 AM
#6795 (permalink)
PaulH
Is it 'stab yourself in the eyeball' irritating like Turtle SVN?
08-07-2014, 08:29 AM
#6796 (permalink)
EV Connoisseur
No.. that's why they created it..
The Following User Says Thank You to flores For This Useful Post:
08-07-2014, 08:54 AM
#6797 (permalink)
PaulH
Well, I think that would be fine then. I just finished the changes for a new command that gives a single stream and then stops. The command is ...
rtd
Boy that was dramatic. I'll email you the code/hex file.
The Following User Says Thank You to MPaulHolmes For This Useful Post:
08-07-2014, 09:01 AM
#6798 (permalink)
EV Connoisseur
Thanx!
08-07-2014, 11:51 AM
#6799 (permalink)
PaulH
For anyone wanting to convert their 0-5k PB-6 throttle to hall effect, you can just take the original pot out and put this in:
http://www.digikey.com/scripts/DkSea...30055978148584
08-07-2014, 12:20 PM
#6800 (permalink)
PLUGnGO
Invalid Request
Paul that link gets a 404. Could you fix it or give some search key words
