Old 11-18-2014, 05:47 PM   #6921 (permalink)
PaulH
MPaulHolmes's Avatar
I think I forgot to mention b- on controller goes to b- on battery pack and also to motor-. Did you do that? And then b+ on controller to b+ on battery pack and motor+ on controller (all 3) to motor + on motor.
kits and boards
Old 11-18-2014, 05:49 PM   #6922 (permalink)
Hi Paul
Should I have changed the "C" file - I just changed the Hex file for the one you e-mailed not the other two
Old 11-18-2014, 05:53 PM   #6923 (permalink)
yes
Three motor +ve to my reversing contactor
Battery minus to the motor and the controller
Battery +ve to the controller
Yes - I was worried that I had done it wrong so I put it back in to check it
just now
The check confirmed the same problem
Can I check the parameters using the serial port??
Or using the PiCkit??
Old 11-18-2014, 05:53 PM   #6924 (permalink)
PaulH
No you just need the hex file. I'm at the store, but will check the code for my boo boo as soon as I get home.
Yes, you can check with the serial port. Type
config
That should show the current settings.
kits and boards
Old 11-18-2014, 07:19 PM   #6925 (permalink)
Hi Paul
RTD - config did not work
I went back to the PiCkit
This time I imported your file -
Hex file loaded successfully - great - I thought I was finished
Then I hit the "Connect" button
All sorts of things started happening
I think I had only put the new hex file into the PiCkit
Now I may have put it into the controller
Back to shed - to put it back in the car
Old 11-18-2014, 07:56 PM   #6926 (permalink)
Ok
put it back in - no change
So its back here next to the computer again
I will see if I can get RTD to work
Old 11-18-2014, 08:19 PM   #6927 (permalink)
PaulH
I'm trying to program at the moment, but my wife has a very thorough story at the same time (as I type). I hope she doesn't read this. haha. So, I won't be able to concentrate until the story is over.
edit: story done! Let the debugging begin!
edit2: story starting again.
"Can you take out all the garbage." yes. OK now I'm ready to start.
kits and boards
Old 11-18-2014, 08:24 PM   #6928 (permalink)
I have only a couple of questions, the WHAT is connected to the What" mosfet, MLCC OH BOooy, seriously I admire anybody that understands all of this. I cAN only assume that I would electrocute myself and or start an electrical fire if I tried to duplicate any of this technology. But seriously guys/girls, WOW I feel so uninformed and uneducated in the field of electronics--Good Work!!!
The Following User Says Thank You to exccel For This Useful Post:
MPaulHolmes (11-18-2014)
Old 11-18-2014, 08:33 PM   #6929 (permalink)
PaulH
hahaha. I know! It took a year or 2 before any of it started making any sense.
kits and boards
Old 11-18-2014, 08:36 PM   #6930 (permalink)
Hi Paul
I can get the PiCkit thing to respond
but when I hit "verify" it comes back with an error message
Can't get RTD to see the thing at all
The Following User Says Thank You to duncan For This Useful Post:
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
