Old 03-04-2018, 11:04 AM   #7241 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Since I'm at it
I had to sort of organize the files I got from Paul. So here is the latest that I have for the AC controller
Only the source fits into a zip file. The 2 schematics and the pcb are too big.
Daox - if you pm me your email address, I can send to you direct.
File Type: zip archive_MPaulHolmes_Email_2017Jan03_AC_Source.zip (95.9 KB, 88 views)
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
Old 03-04-2018, 11:08 AM   #7242 (permalink)
And one more
This is the code to use the AC controller as an inverter - like the ones that you get to run tools from 12V batteries, or from your diesel work truck.
This one will work at whatever voltage you use on your pack. If you use about 150V, paul says it will do a pretty good job of 120VAC. Paul said that it worked to do 240VAC .. but I have not seen that as yet.
I'd expect to use 300VDC bus for 240VAC output, but that's just what I've seen on other inverters.
I was going to try to run a sump pump on 120V output from a 48V pack on my carryall. If it pumps - great! It may need a boost stage to bring the pack voltage up to 120 - 150 VDC to operate properly .. not sure.
File Type: zip archive_MPaulHolmes_Email_2017Apr10_AC_Inverter.zip (36.9 KB, 59 views)
Old 03-05-2018, 02:06 PM   #7243 (permalink)
jackbauer's Avatar
Ok so nothing on the old 500 Amp DC controller?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 03-05-2018, 08:54 PM   #7244 (permalink)
Sorry - didn't know that was what you were looking for.
I have files from Sep 2015. That was the last time I emailed them to someone.
They appear to be Rev2c, pdfs of artwork instead of .sch and .pcb files. I don't appear to have those. A BOM, pdfs of the schematics.
I have similar for for Rev 2b, but not as complete.
The software I have is an html capture of the code. It looks like you can copy and paste to AVR studio and create the 3 files required. Not exactly what i had hoped I had .. but better than nothing? Software is Cougar 1.11b
They are too big to post here, being mostly pdfs. If you are interested, PM me the email address you want them sent to.
The Following User Says Thank You to thingstodo For This Useful Post:
Old 03-05-2018, 08:55 PM   #7245 (permalink)
Ok thanks. Is there any info on the old 500A logic board?
Sorry - I didn't see this post - it was in the middle of my posts
Old 03-10-2018, 03:15 AM   #7246 (permalink)
jackbauer's Avatar
PM sent. Thanks.
www.evbmw.com
Old 03-11-2018, 04:03 PM   #7247 (permalink)
Smile
Damien, here is a link to files on 500A cougar controller. Go to adam brunette forward slash firmware.
Old 03-14-2018, 04:19 AM   #7248 (permalink)
Hi Guys
As I'm "Beta testing" Pauls "Stinky Diaper" - or is it the "Diarrhea" - anyway the High power DC controller
I should update
At our 1/8th mile drags on the 4/3/2018 - I did not get a single error or drop out!
On the other hand I did blow one of the armature windings into copper vapour at the end of the first run
So I'm off the road until I get another motor
I think the controller is fine - have to wait until I get another motor - or that one fixed - to know for sure
The Following User Says Thank You to duncan2 For This Useful Post:
thingstodo (03-15-2018)
Old 04-09-2018, 01:25 AM   #7249 (permalink)
Originally Posted by duncan2 View Post
Hi Guys
I should update
hi, i would like to build this microcontroller and add some modefction, in order to run 3 engines. but i can't find most of the files needed, both in fabrication and in code. can you send me please ?
Old 04-09-2018, 11:51 PM   #7250 (permalink)
This controller is not the original 500A cougar controller. It is much larger, rated about 400V instead of 144V and 1600A not 500A.
I think this one would work better for your 3 motor application, since there are 3 IGBTs and 3 output cables that are normally all connected together .. but you could use one motor per IGBT.
I PMed you - if you respond with your email address I can send you the files that I have. The high power version has the .PCB files and .SCH files as well.
MPaulHolmes (04-11-2018)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
