Old 03-20-2012, 02:50 PM   #11 (permalink)
...beats walking...
Originally Posted by RunningStrong View Post
Omnivores my ass...
...uh, didn't notice my use of the 'weasel-word' "...almost..." did you?
"...diesels are almost omnivorous, while gasoline engines choke on almost anything but petrol."
Old 03-20-2012, 03:04 PM   #12 (permalink)
Panzerwagon - '02 Skoda Fabia
90 day: 53.88 mpg (US)
Sorry, I assumed you were referring to water and pixie dust.
Old 03-20-2012, 03:16 PM   #13 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
I know he lives in the UK. But DPF, DMF and expensive fuel systems are not constrained to just VAG motors.
Tell me about it
I'm seeing my share of troubles with a PSA / Volvo engine and assorted accessories.
I'd advice against a diesel.
The way things are looking, the "clean" diesels with DPF etc. could well become the most harmful of them all !
How about natural gas ?
Cleanest fossil fuel, with potential to get it from biological , renewable sources as biogas ?
Could come cheap in the form of some second hand Fiat .
Old 03-20-2012, 03:21 PM   #14 (permalink)
euromodder's Avatar
Omnivores my ass...
Indeed.
Modern diesels have become very picky in their fuel choice.
Matter of fact, with today's DPF systems, they can't even take high biodiesel content any more !
In Germany, it's nearly killing part of the biodiesel industry as the cars that could take biodiesel (RME in Germany) are slowly disappearing.
It's only the 5% mix in regular diesel that keeps them going - but it takes 20 cars to get to the fuel needs of just 1 car running at 100% BD !
Old 03-20-2012, 04:44 PM   #15 (permalink)
...beats walking...
Uh, diesel engines and dumkoph gobberments are two totally different things, although they both DO seemingly work under high-compression ratios: much IN, much ado OUT.
Old 03-21-2012, 02:28 AM   #16 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Originally Posted by euromodder View Post
Indeed.
Is there any sort of easy checklist for converting/modifying modern diesels to run on WVO/WMO?
Old 03-21-2012, 02:55 AM   #17 (permalink)
euromodder's Avatar
If it's got a DPF, you can forget about using biodiesel (RME, FAME - either as 100% or high-% blends), and vegetable oils.
Old 03-22-2012, 03:39 AM   #18 (permalink)
You have to go for older diesels without, or pray that they start converting them to run with a fifth injector in the exhaust to enable the DPF.
Even then, biodiesel has its effects on engines... you can actually see valve recession on some engines when running biodiesel. Straight veggie oil is a little better, but it's solid at low temperatures (which is why they convert it to biodiesel). It still washes in to the engine oil over time, requiring more oil changes.
Gasoline engines can run run E85, E100 or LPG (with different injectors). Same problem, LPG... valve recession... but it depends on the motor.
Turbos, DPF and Dual Mass Flywheels are all expensive items...
Hear, hear... DMFs are a pain in the ass. At least there are some companies selling SMF conversions, as long as you can put up with the clatter...
