Old 01-26-2010, 08:36 PM   #21 (permalink)
...beats walking...
...well, hold onto your fears because DARPA and NASA are looking into ceramic jet engine turbines held within plastic (carbon-fiber) outer housings...super, SUPER lightweight and capable of producing 'near' after-burning power levels during a finite (ie: "oneway") lifetime/flight duration.
Old 01-26-2010, 08:44 PM   #22 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by smflorkey View Post
Yes, plastic does not last. I have had two Hondas blow chunks out of the top radiator tanks -- PLASTIC radiator tanks! The only thing the mechanic can do is replace the whole radiator.
I understand the radiator core is aluminum to save weight and money. Brass and copper are much heavier and more expensive. But aluminum is much harder to solder, even with the right materials, so the most cost effective thing is to put plastic tanks on the ends of these aluminum cores. They're light and relatively inexpensive, but I'm almost to the point of just replacing Honda radiators every ten years so I don't find myself driving a green cloud down the highway.
And they want me to trust a plastic engine block? Even with iron cylinder sleeves and crank/cam supports, I don't trust the plastic to keep the iron together very long. I won't buy one if anything else is available. YMMV.
That's not true at all. The mechanic is only replacing the core entirely because he either doesn't know how/where to get the end tanks, or doesn't know how to replace them. This is quite common. In fact, 80% of "throw away" parts are still repairable. I do it alot.
Old 01-26-2010, 08:45 PM   #23 (permalink)
Plastic isn't carbon fiber, that I know of... if they're using carbon fiber, there's a good (light weight/super strong/resilient) reason for it.
Old 01-26-2010, 09:29 PM   #24 (permalink)
...beats walking...
...isn't carbon-fiber bonded using epoxy which is generically a variant of plastic?
Old 01-26-2010, 09:39 PM   #25 (permalink)
Polyester, but the resin is for bonding and hardening, the CF is actually the strength of the part.
I see what you suggest, though.
Old 01-26-2010, 09:43 PM   #26 (permalink)
...beats walking...
...as Mr. Robinson confided to Benjamin in "The Graduate": "...plastic!"
Old 01-27-2010, 08:05 AM   #27 (permalink)
Draco - '89 Ford F150 ext cab shrt bed XLT Lariat
90 day: 16.45 mpg (US)
I have looked into replacing the side tanks but usually the rad core is kinda crusty, not to mention I dont trust recrimping the tiny tabs that hold the tanks on.
Because we are big dumb redneck Americans and we only want V8s that thunder and use lots of gas pushing our empty Super Duties down the highway at 100 MPH in the fast lane while warming our butts in heated leather seats and chowing down on double quarter pounders and texting on our cell phones. We cant understand non-V8 engines because that ain't whut NASCAR uses...
Not this American.
Old 01-27-2010, 09:34 AM   #28 (permalink)
When you replace the end tanks, those tabs do nothing but hold it in place, they don't seal it. Once the sealant cures, they're not even necessary. I use ratchet straps to tighten them down, but I'm not sure what kind of "glue" I have.
Old 01-27-2010, 12:29 PM   #29 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
From what I remember from a materials class I took (10 years ago now so I might have the terms a bit mixed up)
Most materials have a fatique limit, if you stay below that amount of force there is no permanent deformation of the material. Plastic doesn't have that limit, which means any force applied causes at least some deformation.
Now with the plastic engine block, unless it has a metal structure that is then covered in plastic that the head, and bearings bolt to, the crank will slowly over time stretch down away from the head. The engine will slowly loose its compression ratio, and will start dumping oil out of the front and rear main seals as they will become ovals instead of circles.
Truly a throw away design.
Old 01-27-2010, 01:01 PM   #30 (permalink)
Imagine for a second that plastic doesn't necessarily mean the stuff your soda bottles are made of...
Plastic means any materials which contains properties which are plastic-like. They're using composites in the design because the composites are/can be made close to the strength of some metals with minimum stress warpage (into the thousandths of an inch per Nth force).
I'm not reading too far into it, because unless I cast one myself, I'll likely never see them, but it's still a rather interesting concept, just like compressed graphite, which also "would never work" before it was implemented, and eventually did work.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Replacing metal body panels with plastic silverhawk_184 EcoModding Central 8 12-07-2010 07:18 PM
Tap Plastic How-To Videos cfg83 DIY / How-to 4 02-12-2009 12:05 AM
Poll for Americans: What about Diesel engines? hal9999 General Efficiency Discussion 117 01-07-2009 07:23 AM
The Cars GM Needs To Make Big Dave General Efficiency Discussion 66 01-05-2009 03:18 PM
