Old 12-29-2009, 02:41 PM   #21 (permalink)
...beats walking...
...exactly what I said with each headlamp assembly: "...arm's getting tired..."
...and, basically, I got the same results.
Old 12-29-2009, 07:39 PM   #22 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
Thanks for linking the youtube vid.
Dave
Old 12-30-2009, 07:59 AM   #23 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
That looks good!! How did you fabricate that air dam? Have you been able to notice any difference?
Old 12-30-2009, 08:04 AM   #24 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
The key to keeping yer polished plastic lights looking new after polishing is sealing them with some clear spray after polishing them clear.
I don't have U-Pol clear available to me...so I just used some Rustoleum clear coat spray paint (non-UV) from Walmart about 8 months ago when I polished my headlight lenses. I was not able to find a source fer the UV resistant clear coat spray paint locally so I just got the normal clear spray. The clearness of the lens is holding up much better than one with no added coating on the lens. Although it's yellowed just a little, it's not hazed over like when I bought the vehicle early this year.
March 2009...
April 2009...
December 2009...
Glassylite is the ultimate lens restoring product kit on the market that includes a clear coating sealant and may be a better kit choice fer the DIY consumer.
Old 12-30-2009, 11:50 AM   #25 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Well...it started with this thread and then went to this thread. Have a twin thread on GasSavers.org as well. Best mileage so far is about 23.5mpg.
The Following User Says Thank You to BamZipPow For This Useful Post:
mikeyjd (05-26-2014)
Old 12-30-2009, 01:33 PM   #26 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
too bad theres no silver painters tape
Past Present Future?
Old 12-31-2009, 05:06 AM   #27 (permalink)
I don't think I've ever had a yellowed headlight. Even my 94 has clear lenses. Every time that I wax the car I do put car wax on them, may be that helps. Next time that I get the buffer out maybe I'll spend a few extra seconds on them.
BamZip, I like the air dam extension that you modified, around here, that be a snow pusher! Really nice job, what did you use?
Dave
Old 01-01-2010, 07:53 AM   #28 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
Last 3: 24 mpg (US)
Talking
Dave
Thanks Dave! You should read my build threads...
Let's see...
Coroplast, 4mm
1/4"-20 thread all
1/4"-20 "T" nuts (flattened out)
1/4" washers
Schedule 40 1/2" PVC pipe
zipties
shelf brackets
bolts
1"x2" wood
screws
As far as I know...I'm the only T-100 with a dropped and bumped air dam.
Gitting back on the subject...
I used a palm sander with some 1500/2000 grit wet/dry sandpaper to git most of the hard stuff off. The key in using this setup is keeping the surface wet with some soapy water in a spray bottle. I followed this up with some plastic polish on my buffer pad mounted on my drill. Sprayed it with a coat of clear and let that dry. Polished that down and sprayed it again. After that dried...I polished it one more time. Presto!
Old 01-01-2010, 09:12 PM   #29 (permalink)
Ranger - '93 Ford Ranger XL 4x4
90 day: 22.28 mpg (US)
i used the 3 m kit on my ranger and the lights look alot better.
Old 01-02-2010, 12:31 AM   #30 (permalink)
ton
It's simply amazing -I've done it.
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 457 02-11-2022 03:57 AM
I basjoosed my headlights today (sealed the surrounding gap) MetroMPG Aerodynamics 43 11-18-2013 07:55 AM
Sunfire headlights are stoopid! bennelson Off-Topic Tech 15 05-05-2012 07:53 AM
DIY LED Headlights SVOboy EcoModder Blog Discussion 44 09-06-2011 07:48 PM
Wanted: Metro Headlights Demon-Hemi For Sale 3 04-21-2009 09:28 PM
