Old 03-26-2015, 04:31 AM   #1 (permalink)
Bataleon's Avatar
Angry Poor fuel economy over short distances
Hi all,
Most days I make a two mile trip (each way) to campus and back in my manual 2006 1400cc Volkswagen Polo (2200 lbs curb weight).
Yesterday I measured my fuel economy during the two mile trip home (using Torque App) and got an average reading of 19.4 mpg(US). This morning I averaged 28.3 mpg(US), slightly better because it is downhill most of the way.
These figures are pretty poor considering:
  1. It's a small car with a small, relatively modern engine
  2. The ambient temperature was around 72F
  3. Tires were pumped to 44 psi
  4. I was hypermiling where I could.
Do you think there's something wrong with my car?
Thanks in advance.
Old 03-26-2015, 04:40 AM   #2 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Probably nothing wrong with the car, just the commute. It's too short to properly warm up the vehicle. I'd ride a bicycle for such a short distance.
The Following 3 Users Say Thank You to redpoint5 For This Useful Post:
Daox (03-26-2015), Isaac Zachary (04-10-2021), Joggernot (03-27-2015)
Old 03-26-2015, 04:55 AM   #3 (permalink)
Bataleon's Avatar
Good advice. I'm going to start using my bicycle a lot more now.
The Following User Says Thank You to Bataleon For This Useful Post:
Old 03-26-2015, 04:56 AM   #4 (permalink)
90 day: 49.01 mpg (US)
My wife drives It in town only. It seldom drives further than 3 miles in one go.
She is not into hypermiling (to put it mildly) but I doubt it would have a lot of effect anyway.
Check out It's fuel log...
In absolute terms It does not use a lot of fuel though. The tpg (trips per gallon) rating is outstanding.
Old 03-26-2015, 05:09 AM   #5 (permalink)
Bataleon's Avatar
Interesting figures, thanks RedDevil.
Old 03-26-2015, 06:21 AM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Use of a block / coolant heater would help some in a vehicle that does short trips, even in warm ambient temperatures. Of course that only helps with coolant temp. Efficiency is still going to suffer from other cold drivetrain components like the transmission, tires, etc.
Old 03-26-2015, 07:07 PM   #7 (permalink)
Yup all cars get terrible gas mileage the first few miles. Modern cars have some insulation for the fluids and thermal management to warm things up faster (so your second trip takes less warm up time) but you still need to warm it up the first time.
Old 03-26-2015, 07:20 PM   #8 (permalink)
101Volts's Avatar
Woody - '90 Mercury Grand Marquis Wagon LS
Last 3: 19.57 mpg (US)
Brick - '99 Chevrolet K2500 Suburban LS
Last 3: 12.94 mpg (US)
M. C. - '01 Chevrolet Impala Base
90 day: 17.09 mpg (US)
R. J. - '05 Ford Explorer 4wd
90 day: 16.66 mpg (US)
I thought Diesel_Dave was heating up the transmission pan, oil pan and coolant before he started his truck (With pad heaters?) though. It helped him.
Old 03-27-2015, 10:19 AM   #9 (permalink)
Bataleon's Avatar
Question
Interesting idea.
When I start my engine it idles at 1200 rpm until the coolant reaches 140°F (60°C) after which the revs drop to 850 rpm. At the same time the fuel flow rate drops from 40cc/min to 20cc/min.
Why is this? It seems like an unnecessary waste of fuel considering the ambient temperature is around 72°F (22°C).
Is there anyway to disable this or is it automatically controlled by the vehicle's ECU?
Old 03-27-2015, 10:34 AM   #10 (permalink)
Its automatically controlled, every engine does it. A warm engine is an efficient engine. Fuel vaporizes properly with a hot combustion chamber, components expand with heat, and many other things. Engines need to be warm to be efficient.
fuel economy, hypermiling
