Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 11-14-2009, 07:21 AM   #1 (permalink)
Cool Presenting the Redneck Recumbent
Yeah... went off on another tangent the other day...
The Following 3 Users Say Thank You to Frank Lee For This Useful Post:
aerohead (10-06-2014), California98Civic (08-28-2014), thatguitarguy (11-16-2009)
Old 11-14-2009, 09:17 AM   #2 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Go FrankLee !!
You call yourself a redneck? The paint matches, and its not just primer.
Tell me that you used rattle cans not real paint and I might respect you again
Red and Black, you a bulldogs fan?
Honestly, how does it ride? Got the shifter hooked up yet?
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 11-14-2009, 09:17 AM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Nice wood work on the seat Frank Lee..............(did you even sand it)
Old 11-14-2009, 09:35 AM   #4 (permalink)
I hope it doesn't go too well, 'cos it sure isn't going to stop...
Old 11-14-2009, 01:53 PM   #5 (permalink)
The paint is factory original purty.
I thought the plywood and board seat qualified it for redneck status!
I did sand the slivers down from the fresh cut areas. That's it tho'. That seat is more comfortable than it looks. Even with no pad it seems to beat a regular seat even with a gel pad.
Thought it would do for prototyping/testing, until I determine if this thing is junk or not.
It rides like... a recumbent. That is to say, either I'm a clod or you kinda have to re-learn how to ride a bike, just like a little kid. I haven't crashed it tho'! Shifters and brakes = not hooked up yet. I'm not ready for the top gears anyway. The ergos seem great- very comfortable- but then I don't have any lengthy rides done yet.
Edit: One more comment about ride quality: As you can see, there will be no sharp turns done with this set-up, at least until I learn to release my "outer leg" from the pedal. Considering adding rear wheel steering...
Old 11-14-2009, 01:59 PM   #6 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Great job, Frank. Expected nothing less than a plywood seat from you... honestly.
Old 11-14-2009, 02:45 PM   #7 (permalink)
I didn't even have to fire up the welder!
Or buy so much as a single bolt. At first I was just going to sort out the ergonomics... wanted something to sit on... went back to the woodpile and picked out stuff that was about the right size... and there it is. Didn't even cut the seat back to size!
What? And sand that nice brown paint off?!?
At 22.5" at the lowest point, the seat height is decently low for such a bike.
I'm going to fab up a different handlebar set-up. My knees brush against this one.
If the concept proves itself I'll make nicer components.
Old 11-14-2009, 03:46 PM   #8 (permalink)
You may want to consider a lower Cg to aid stability, but I believe you'll enjoy the recumbent position.
Old 11-14-2009, 06:37 PM   #9 (permalink)
mcrews's Avatar
Frank Lee, I'm sorry I questioned your "REDNECKEDNESS" concerning the seat......
I DIDNT EVEN THINK THAT THERE ARENT ANY BREAKS!!!!!
You are back up (or down) in the evolution pecking order.
(gotta give you credit for not firing up the welder......)
Old 11-14-2009, 07:37 PM   #10 (permalink)
Gen II Prianista
Rokeby's Avatar
But I take it you did fire up the Sawzall on the donor bike,
which appears to have been a "boys" bike.
I suspect you had to pry the front fork tubes outward quite a bit to accept the
the rear wheel axle. I would expect something like 1-1/2 inches. That would
create a severe bending moment at the crown where the fork tubes attach to
the crown. Better keep an eye on that area for micro-cracking, in the
weld/silver solder, whatever.
"Be careful out there!"
First ride on a (semi-)recumbent bicycle: BikeE - got a CCM Evox 120 MetroMPG Alternative Transportation 20 11-14-2011 08:29 AM
Video: nice little recumbent tadpole trike MetroMPG Alternative Transportation 7 09-30-2009 12:30 AM
JohnPR's oficial recumbent trike build thread johnpr Alternative Transportation 5 05-22-2008 12:50 AM
My Recumbent Thread - I found my 'bent trebuchet03 Alternative Transportation 4 12-31-2007 08:41 AM
