Old 06-15-2019, 12:56 AM   #61 (permalink)
Ecomodding Apprentice
Going to leave on the heater to cure off then make a mirror support. I'd estimate 270g including glass when done..
ID:	26190   Click image for larger version
ID:	26191   Click image for larger version
Old 06-16-2019, 03:59 AM   #62 (permalink)
The mirrors are a way off but all the parts including the glass pretimming weigh 225 so would think 220g would be the final ball park for them
Nearly finished mirrors, now I read this https://asia.nikkei.com/Business/Com...s-in-new-model
Going to keep mirrors but may replace the glass with 2mm acrylic
Old 06-18-2019, 11:44 AM   #63 (permalink)
Lower section had a small window fitted
Old 06-18-2019, 11:50 AM   #64 (permalink)
Well anyway I was on the way to work and a great idea popped into my head. So I turned around and did this...
ID:	26212   Click image for larger version
ID:	26213   Click image for larger version
Old 06-18-2019, 11:52 AM   #65 (permalink)
Incidentally while messing with my car I've found a few of these weights, exactly 1kg, huh
Theyre in places you wouldn't look
Old 06-18-2019, 11:55 AM   #66 (permalink)
I made some small plywood inserts..
Also aren't women so annoying
ID:	26216   Click image for larger version
Old 06-18-2019, 11:56 AM   #67 (permalink)
Thats right toyota didn't spray under the number plate tut tut
n.b if anyone's weights have fallen off you can have my ones
Old 06-19-2019, 06:47 AM   #68 (permalink)
I did 0-60 yesterday, 8.2s. Disappointing as I though it was around 7
Anyway weight was questioned before, so 110hp at 8.2s = 857kg
My other prius battery (lower mileage) feels a bit more spritely so a clean of the busbars and a fully warmed up battery I think could get that comfortably down to under 8
Also found another kg weight..?? Theres no way it's a futuristic vehicle!
It does pickup faster on hot days after a run, this was midway between warmed up
Old 06-19-2019, 11:45 AM   #69 (permalink)
The bumper is nearly done however the last parts it has to be turned upside down and it will be a two day dry...I dont want to move it until its completely hardened. It will also need work fitting and aligning
I would think if you have a very tight budget, 300g woven glass fibre would still give very good results, a 3rd heavier than carbon but less than half price
Old 06-19-2019, 11:46 AM   #70 (permalink)
Well I'd say the gearbox was futuristic. And once ceramic neodymium becomes mainstream in a few years that might be something (its made organically by really clever japanese guys) A++
