Old 06-30-2022, 08:04 AM   #291 (permalink)
Ecomodding Apprentice
Originally Posted by mohammad View Post
if you dont mind me asking why do you use premium gas if your goal is to save money?
E10 has more ethanol which will ruin my engine quicker, that does not save me money. I could take it out but don't have time or time spent otherwise eating cookies
Old 06-30-2022, 12:51 PM   #292 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Battery swaps dont work for 3 main reasons
I had once considered a portable battery I could charge from a standard wall outlet at work. In the winter, I'd fall short of my round trip in the Prius plug-in by about 1 mile. If I could put just 1 kWh into the car once I got to work, I'd be able to make the whole trip.
Probably could have negotiated with security to let me charge for 30 minutes behind the building where the golf carts were plugged in.
Old 06-30-2022, 05:23 PM   #293 (permalink)
8 years ago I considered stripping a leaf plus I had electric included in the rent.
I think it would have to be multiple portable units, I prefer NiMH so would be very heavy
If you had used one li would have probably done it, or garaging your car/not defrosting possibly, radio off and stay on dipped but you likely tried that. Sometimes it takes a few days for changes to show up
Old 07-02-2022, 12:20 PM   #294 (permalink)
I kept figuring out how to make the castors lighter and tried this. It worked well. They're still too strong and heavy for purpose but I didn't have time to make any
ID:	32524   Click image for larger version
ID:	32525   Click image for larger version
ID:	32526   Click image for larger version
Old 07-08-2022, 10:05 AM   #295 (permalink)
Only around 110g but it's the highest part. I think I will make a small portable lathe from a bench grinder
Also making extended feet. Around 350gsm with wooden kebab skewers inside. Not as strong as the chassis tie, about half, and should put the working height up 9-10 inches. Mixing time with epoxy seems more important than ratio, in my experience so far
ID:	32562   Click image for larger version
ID:	32563   Click image for larger version
ID:	32564   Click image for larger version
ID:	32565   Click image for larger version
ID:	32567   Click image for larger version
ID:	32568   Click image for larger version
ID:	32569   Click image for larger version
ID:	32570   Click image for larger version
Old 07-09-2022, 02:42 PM   #296 (permalink)
80 new 6061 t6 M6 but 12mm this so there's more thread with a washer and a new radiator sensor. Will do strength tests next week
ID:	32577   Click image for larger version
The Following User Says Thank You to Nathan jones For This Useful Post:
Joggernot (07-10-2022)
Old 08-03-2022, 06:29 AM   #297 (permalink)
Not alot going on. To start the test, I set the torque wrench to 60mn it's lowest setting and used a regular non carbon steel bolt as a starting point but the thread pulled before 60 so I've ordered a much smaller wrench....
Also soon I will order some material for my rear exhaust box that I plan to rivet and braze. When I get time....
Also the last bolt is threaded rod, I read once it's stronger than cut bolts because the rod is rolled, but who knows until I break it...
And the material I'm ordering is aerospace stuff unusual for exhausts....
ID:	32700   Click image for larger version
Old 08-03-2022, 06:58 AM   #298 (permalink)
Premium does not necessarily contain less ethanol.
Oil pan posted a video in his leaf pusher thread that you may find interesting. It also shows how to test ethanol content.
You can find it here.
https://ecomodder.com/forum/showthre...tml#post671369
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
Nathan jones (08-06-2022)
Old 08-06-2022, 06:22 AM   #299 (permalink)
That is true in detail but in the UK tests show the worst premium fuel contained 8%. None had less than 5
By adding ro or deionized water, shaking and letting rest you can filter it but I don't have time. Also by the time valve heads and piston surface are sufficiently degraded my bearings will all need replaced
My brake lines are ok at the moment but has anyone experience of aluminum lines used on airplanes? I can get 1800 psi stuff and it's used the same way as copper, just not 8gcm
And real experience...??
Old 08-06-2022, 08:00 AM   #300 (permalink)
Unless the alum lines are really cheap and anodized, I wouldnt use them. Aircraft don't: operate in salty environs, have dissimilar metals to attach stuff, dont use alcohol based water attracting fluids they use mil spec hydraulic oil.
