Old 04-02-2021, 03:10 PM   #11 (permalink)
Originally Posted by Isaac Zachary View Post
Ya, some of those points I already knew. I also learned some too, so thanks!
From what I can tell the guy is quite the amateur who exaggerates a lot in an attempt to convince everyone. It does seem like he might be hiding something and trying to cover it over with exaggerations. Or he's just exaggerating to try to convince everyone.
But in the end, I don't see any real advantage of his product unless it had more capacity. If the lithium battery has less of an internal resistance it may soak up and let out more of it's capacity than the NiMH. But he doesn't explain how he knows that for sure.
I don't have hard data, but I've done extensive testing on both LFP and NiMH. The LFP voltage curve is flatter for a very large portion of its capacity. From a pure performance standpoint:
EV range will be farther.
Peak power can be sustained for longer periods.
Likely mpg improvement in driving scenarios where hybrids offer advantage.
However, ALL of the above will come at the cost of reduced battery life. Until I see cycle life vs. DoD curves, they're just blowing smoke.
I am NOT anti-LFP. I have about 10kWh of it in loose CALB cells. Pretty amazing chemistry, but I'm aware of some hurdles that need to be overcome by managing kW input and output limits based at least on voltage, and they've stated they don't modify the ECU. They're counting on a "feature" of LFP that will be exploited routinely and likely result in premature loss of cycle life.
I'm anti marketing-bull****-passed-off-as-training-or-technical data and DIY hacks trying to come off as experts.
If they spoofed the HB computer with block voltages that allowed accurate representation of the needed SoC to kW management scheme appropriate for LFP, they could compromise the performance benefits and settle on a design that performs a bit better and likely lasts longer.
I'm tempted to buy a C pack to test the **** out of the modules.
Old 04-02-2021, 03:55 PM   #12 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
His product could be sold for 1/3 his current retail
If he would use that advantage...
But he likely wants to make the most out of limited demand
Old 04-02-2021, 04:59 PM   #13 (permalink)
Commodity LFP is about $120/kWh.
His pack is 1.5kWh.
He's priced at about $1300/kWh for the Prius pack.
Granted, there's some engineering in there, and evidence of a rudimentary BMS, but mark-up seems a little high.
In addition to limited demand, once this is subjected to the abuse of the unwashed masses, it will likely emerge as no better than the garbage "D" cell kits you can get from China.
Old 04-02-2021, 06:53 PM   #14 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Wow! Where could I find some at that price! Is this the price for cells with such a high C rate. 120amps at 6ah is 20C.
Of course if I could get some 40ah cells at 3C rate, that would be even better.
His pack is 1.5kWh.
Ya, it's hard to beat tried and true OEM batteries, which can cost similar if not cheaper than this.
Old 04-02-2021, 07:13 PM   #15 (permalink)
"commodity" is more commonly used for power storage, not EV or high drain - typically 1C with capacity in the 280Ah/cell range.
Late last year I bought 9 Eve cells from a supplier in China delivered for about $122/kWh.
